Question about Whirlpool ED2SHAXM Side by Side Refrigerator
How to remove freezer door
I need to remove both doors of my Whirlpool refrigerator in order to move it to another room. The right door is no problem. The left door (freezer) has a water line that connects at the bottom. There is a 1 1/2' white connector in the water line that doesn't seem to come apart. It is one piece and there is a red plastic washer at one end and a blue plastic washer at the other end through which the water tubing runs.
Can the tubing be removed from this connector and if so, how? I didn't want to force anything yet. If not, I guess I'll just have to cut it out and replace it with some other connector.
Thanks for any help.
Richard
  • Anonymous Aug 31, 2008
    I have a side by side refrigerator (Whirlpool), I need to take the doors off. Right one - no problem, left one has a clear tube connected for the water line for the outside water dispenser. How to I take off?
    ED27
    Sniper:
  • 65 Answers
Push colored rings toward white collar while pulling hose from coupling
Posted on Feb 16, 2008
Taking bottom freezer door off
Posted on Apr 22, 2011
The freezer on my French door fridge is forming frostl. Why is this happening.
Is it frost on the freezer inside back wall or inside freezer towards the freezer door on the top of inside freezer box. If back wall then you have a defrosting problem. If it is towards freezer door then you have door seal problem and moist room air is getting inside your freezer.
Oct 13, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
I was given a Whirlpool ET1FTK 20.8 cu ft refrigerator/freezer. Door frame going thru is 29 inches. Need to take off doors of fridge to get in house. Anything you can send me. Don't have any of the books...
Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Eric
Nov 03, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Want to move whirlpool american side by side fridge freezer but need to remove doors how is this done
1. If you just need to gain a little space you can simply remove the door handles. They should just lift (or slide) up with moderate force and can be removed.
2. If you only need to move through one door in a building you might be able to open the doors enough to make the unit clear the door you are trying to move the unit through. This would take care.
3. If you really do need to remove the doors, be sure to disconnect the water line at the rear. Then gently snap off the hinge assembly covers at the top of the unit and disassemble the hinge. Be aware of water lines when you are ready to remove the doors.
dwilli10
Jul 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
How do I order new refrigerator door?
Have you tried the manufacturers web site?
Apr 29, 2009 | Whirlpool GD2SHGX Refrigerator
Fallow tubes where they go up[ into door if where the front leveling legs are i has a cover take off cover if tubing is in these areas should be a quick disconnected if it also the area where the bottom door hinge just go up tubing then down and back will be there some where.
Mar 16, 2017 | Refrigerators
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
2,521 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
