Back to:
Tags:
Achiever 260AF for Nikon TTL Flash
Achiever 260 AF for pentax
posted by rolfkj on Jan 31, 2008
Will my Achiever 260AF for a 35mm Pentax work without damaging my new Pentax K100D SLR? The Achiever was bought about 11 years ago.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 07, 2008
Not Rated (0)
eltroman
Rank:Wiz Wiz
Rating: 83%, 114 votes
Check the voltage trigger of the flash, if you're under 7vdc. Then you are good to go.
atdlee@netzero.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Achiever 260 AF for pentax:
I don't want to Accept this solution
Can you Help with these Flashes problems?
Flashes
Ringflash will not fire. Contacts are clean. New...
Flashes
Cannot get my speed lites 550EXII as a master unit and my...
Flashes
le detecteur de mouvement ne foction plus
Flashes
Hello I own a Panasonic Lumix DMC FZ50 camera and would...
Flashes
I have a two month old Sandisk2GB MP3 player Which has...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
