Question about Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN437W 43"
Was having problems with it freezing up and would turn off but then i could just turn it back on and it would work for a while. But yesterday I turn it on and the fan turned on and there was no picture just a black screen and the green "lamp" light was flashing and i hear some kind of tone. I am not able to turn set off with power button unless i hold it then it turns off and back on. Some times i get all 3 leds to light up. Any one have any idea what i can do before i spend money for a bulb Want2blile@hotmail.com
  • Anonymous Feb 08, 2008
    I am having the same problem with my samsung tv, did you ever find out what the problem was???
Bulb is no good. Get a new one
Posted on Feb 11, 2008
My samsung mdl# hln437w says check fan 1 2 3
the internal fans has some maitenance, needs to be cleaned/replaced . need to open rear case to acess them.
Feb 09, 2010 | Samsung HLN437W 43" Rear Projection HDTV
TV Screen 'freezing' while watching.
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Nov 18, 2009 | Samsung HLN437W 43" Rear Projection HDTV
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
I have an HLN437W and it won't turn
The problem is the fan behind the bulb or the fan behind filter.
Mar 01, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Samsung tv model HLN437W
first you want to check the lamp, if you see the set from the front you want to go to the left side(on the side not the back) and you will see on the side lamp cover only one screw remove it and you will be able to see the back of the lamp 2 screws take lamp out and inspect it , if bad replace it. some sets will have lamp part number on the side also.
Jul 05, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN437W
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
Mar 02, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Picture freezes Black/White
It's most likely the digital board, Samsung p/n# Bp94-00385a but I'd trace test both the digital and analog first before blindly replacing it - too costly to just guess..
Bill
Dec 08, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
