Question about Panasonic RR-US360 Digital Voice Recorder
Not recording i start recording and everything looks good. when i stop the recording i get an error code EEEE and no files were recorded. is my recorder dead or is there any solution? thanks
  • Anonymous Jul 02, 2008
    some thing
    but I don't know how to set to the phone
My Swann DVR is not recording at all
Posted on Mar 30, 2012
At first set the recording lenght on your phone(example 5 min) and then start recording, after the recording length is completed it automatically saves your recording file
Posted on Jan 31, 2008
Error code recording stopped. Problem with record buffer
I've done some searching this seems very proprietary, I would first try contacting the manufacturer directly to see if t hey can shed some light on this issue.
Jan 23, 2015 | Tascam X-48 48-track Hybrid Hard Disk...
Attempt to copy file from Digital Voice Tracer 7675 to PC. Error msg: Digital Voice Tracer Application has stopped working. I have reinstalled the driver from the original disk numerous times. Is there a...
Try looking on cnet or softonics. (they er free software sites that have a little of everything). if its do-able, you'll most likely find the software there, and its free!! GOOD LUCK!!
Nov 05, 2013 | Philips Voice Tracer 7675
I have an rca rp5022 voice recorder and when I attempt to transfer the files over to my computer an error screen pops up stating the file is corrupted and unreadable. I can listen to the file on the...
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
Sep 23, 2010 | RCA RP5022 Digital Voice Recorder
I have An ERR code. How can I get rid of it without deleting all the files??
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Jan 30, 2010 | Olympus VN-4100PC Digital Voice Recorder
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
No space available.
Format of the DS-30
If you format the recorder, all files will be removed and all function settings will return to defaults except
date and time settings.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens ( P91,93).
2 Press the + or – button to choose “Format”.
3 Press the OK or 9 button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Dec 24, 2008 | Olympus DS-30 Digital Voice Recorder
Is it possible to stop recording without opening a new file?
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
File is damaged error message
Hiya HKL1, incase you've still got the problem with your recorder i thought i'd post a solution. I think you may have renamed the folders after saving your data onto your computer, i dont know how i did it but i did! so the recorder isnt recognising the folders as the ones they started with so you have to format/reset the recorder. good luck =)
Feb 08, 2008 | Sony ICD-MX20 Digital Voice Recorder
Panasonic RR-US360 Digital Voice Recorder Logo
467 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
