Washer will not stop filling up
I have a kennmore washer that is 2 years old.Water will comes into washer at start up however when it gets to the top level on it keeps on running and flows over into the floor. What could be happening. Please let me know, clothes piling up everywhere.
  • raulli23 Mar 09, 2008
    i have a admiral washer, the water will fill up and overflow past its level this machine is 3 yrs old.
  • 125 Answers
Take the 2 screws out of the control panel, either in the front or back, depending on model. You may need to remove covers on the front of the panel. flip up the console. Find you water level switch, on the back of the switch there is a rubber hose. Pull the hose off of the switch and blow into it. if there is water in the machine you should here air bubble out as you blow. this should clear the line from any blockage. The machine should operate normally. most likely lint or something blocked the pressure hose.
Posted on Jan 31, 2008
Washer machine
Sounds like the hot water solenoid is stuck.
Feb 11, 2008 | Kenmore 22422 Top Load Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Nov 18, 2008 | KitchenAid KAWS750L Top Load Washer
Water doesn't stop filling tub in washer, water overflows everywhere. washer doesn't wash on super/large loads and doesn't spin on any loads. washer is only 2 years old
water not stopping filling is the pressure switch its a long thin tube that goes from the bottom of drum to the front top about the thickness of a pencil this needs taking off clearing through and checking for pin holes then refitting this should solve water problem
Jun 19, 2008 | Washing Machines
Getting top off of automatic washer kENNMORE BRAND
You start out by taking the screws out of the console. These screws should be located under the snap off caps on either side of the console. Pop off these caps (front of the console, on either side) and you will see the two screws in the bottom corners. After removing these screws, pull the entire dash unit lightly towards you, the swing the console up and over the back of the unit. You will see 2 gold colored clips on either side of the unit top. Remove these clips by placing a screwdriver in the front most area (area closest to you) and just pop the up, the swing them out of the retainers in rear of the machine. Unhook the set of wiring that goes down into the unit (lid switch wiring). Swing the cabinet at a 45 degree angle towards you, and then lift the hole cabinet off. You will have total access to the interior of the unit. Installation is the same as removal, just be sure you get the front of the cabinet under the lip in front, and the rear of the cabinet gets placed back in the small notches when you fold it back. Let me know if you need further help. Good Luck!!!!!
Jan 31, 2008 | Washing Machines
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
