Question about Panasonic Panafax UF-890 Plain Paper Laser Fax
Panasonic UF-885 Power Cycling
What part is defective if the unit powers on then off and will not power up for more then a second?
Thanks
  • 34 Answers
There are few possibilities....
  1. Power supply unit may be faulty
  2. Possible short circuit or over load from Internal circuit
  3. Low capacity incoming power(mains)
Posted on Jan 31, 2008
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
My 1490 will not power on tried start and even holding power button on for ten seconds
Common problem with these units are a defective USB port that prevents the unit from powering on with an external charger or charging the battery. The unit will appear DEAD. You could have a bad power switch but the unit should still power up when connected to the charger EVEN with a bad power switch. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Dec 11, 2013 | Garmin nuvi 1490T GPS Receiver
I tried to power on our personal computer and it doesn't work. We think maybe the switch in the front could be bad. When we open up the case, there is a green light on, so we think there is power to the...
There is no other way to power up the computer. The green light inside the pc don't mean it is on, it can be only the network card led (that is always on). I suspect a defective unit. Try holding the power button for some seconds if it's booting up.
Mar 01, 2011 | Dell Dimension E521 (D10E16) PC Desktop
Navagon 7100 wont turn on
Hi guimonds,
Make certain you have the unit plugged into external power, and the indicator light (LED) is ON. It would be best if the LED shows "Green", indicating a full charge on the battery also.
Place a blunt-tipped object (larger paperclip or toothpick with sharp end cut off) into the hole at the reset location, which is on the bottom left part of the GPS. Press down for 10-15 seconds on the reset button, then release. Now, press and hold the On/Off/Standby for at least 6 seconds (try 10-15 seconds if needed) to power unit back on. If there is still no power-up, then your unit may be defective. Download the complete 110-page manual from here for more information:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
I hope this helps get it working. If I can help further, please let me know. Thanks.
Regards, Bill
Sep 18, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Codigo sc546 aficio 1035 ricoh
SC546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Dec 11, 2009 | G-Technology WWD-91500101 G Speed 1500GB...
Insignia model ns-32lcd will not power on.
If you wish to get some details; visit the site linked here. Pull up older posts.
May 17, 2017 | Insignia IS-LCDTV32 32 in. Television
Functional problem code SC542-00
Enter SP mode > Clear (yellow) button > 1 0 7 > and press and hold the Stop (red) button for 3 seconds.
Then switch off and on the machine.
If error still there, probably you have a problem in the fusing unit.
Possible causes are:
Thermistor defective;
One of the fusing lamp is open circuit;
Thermofuse open;
Fusing unit connector defective; and
Power supply board.
Good luck and please rate me, thanks.
Jan 21, 2009 | Gestetner Copier
Denon AVR-2309ci receiver keeps losing power after a few seconds
This is a defective unit. bring it back to best buy and have them replace it.
Jan 02, 2009 | Denon Audio Players & Recorders
Sony uvw 1600 betacam sp does not power up
Check the power supply area for the fuses for one. Second, the power supplies in these units are switch mode supplies that require a jump start from a small cap. It is possible that the "starter cap" is defective. There are other reasons for this type of behavior as well. Keep us posted on what you find.
Dan
May 30, 2008 | Sony Televison & Video
Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
May 22, 2008 | Ricoh Aficio 450 Copier
Panasonic Panafax UF-890 Plain Paper Laser Fax Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
