Question about AudioBahn A2150HCT Car Audio Amplifier
Wiring diagram or schematic
My amp is making a humming sound. Even when the volume on the stereo is completely turned all the way down. I was wandering what exactly was creating this problem.
It may be a bad ground that is one of the hardest things to get rid of
Posted on Feb 23, 2008
Also make sure you have a proper earth
Posted on Feb 14, 2008
    New Friend:
  • 101 Answers
Make sure no of the speakers wires,inputs or antenna even cable is runnig parallel wite an electric cord or line.that is 90% reason 4 feedback(humming). Iif you have to cross wires do it in a intersecting way.perpendicully<if thats a word.rating please
Posted on Jan 31, 2008
2000 chrysler grand voyager Integrated speaker amps???
Replace the speakers if they are amplified types.
Apr 25, 2017 | 2000 Chrysler Grand Voyager
Volume only hums. even with volume off.
The unit may need to be looked at by a Technician to determine the cause. Can be power supply, defective amp or head wires broken off the head.
Maybe more
Jun 06, 2012 | Audio Players & Recorders
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
I have hooked up my subwoofer and amp to my factory stereo in a 2011 camry. My power wire is hooked directly up to my battery, my ground to the chassis and my remote to my fuse. I have my RCA wires (RCA on...
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Jun 14, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
jd@oncorpus.com
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Humming
Maybe one of the audio leads does not have a complete earth shield and until the second lead is connected, the lack of a suitable earth shield produces the 50Hz 'hum'.
If you should connect either of the two the centre conductors to your body, YOU will introduce a similar hum due to your body acting as an 'earth' to that signal carrier.
These are frequently common effects and it may be a good idea to turn the volume level down on the amplifier or even turn it and the VCR OFF whilst you make or break these connections.
Good Luck!
Aug 04, 2008 | JVC TH-M505 System
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
750x to 2 10" pyramids
There sould be an input level control on the main amp that drives these woofers. Adjust the input so that even iof the stereo is tuned up all the way the amp is limiting the amout af input. Before you do this and turn up the stereo, turn down the amp input control all the way then you can slowly bring it up when you turn up the stereo's volume. Good Luck
Mar 23, 2007 | Pyramid PWFX107 Car Subwoofer
AudioBahn A2150HCT Car Audio Amplifier Logo
182 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
