Question about Sharp 27C-240 27" TV
Problems with picture coming on.
When I cut on the television I hear the program then before the screen comes into focus it makes a cracking sound and goes to blue screen.
If I cut it off and back on quickly the picture comes in. Can you help?
I had it repaired for $145.00 and now it is working like new. There was a loose connection and it needed to be cleaned due to having a lot of dust inside of the cabinet. The $145.00 paid is considerably less than what it would have cost to purchase a new television.
Posted on Jun 12, 2008
Throw it in the trash
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
Cannot see the picture on my tv
This need an adjustment in flyback screen to make it higher so picture must seen.Open your TV go to the flyback there in the flyback body you can see a little rotary nab for "focus" and "screen"Just only adjust the screen a little until picture comes out.
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Sony Televison & Video
RCA Television Turns on and off
check for cracks solder joints on the diodes coming from the flyback
Dec 02, 2008 | RCA P52926 52" Rear Projection Television
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Sharp 27C-240 27" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
