Question about Mitsubishi WS-55511 55" Rear Projection Television
How do you install the convergence part on a Mitsubishi WS55511 big screen tv? The part has prongs on the bottom but I don't know how to attach it.
You must de-solder the output IC first. Then I would suggest that you remove the heat sink by removing the philips screws holding it to the pc board. you will find white heat sink compound on the bottom of the heat sink. clean this off and remove the output IC. put some heat sink compound on the new IC and install in in the holes on the pc board. be careful removing the solder on the pc board. I like to use solder wick. Install the new IC and solder it up as the old one was. remember to check the convergence in both analog and digital, as you have to converge both for it to remember the settings. Hope this helps. TV repair guy :)
Posted on Jan 31, 2008
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Convergence alignment is off. How do I fix it? I idont have original remote for tv.
Almost any Mitsubishi big screen remote will work for this, no real way to attempt to adjust without one
If convergence is really skewed it will not align--see attached photos.
Convergence problems are common in these sets--it can be a do it yourself repair if you are handy and I have start to finish instructions for most of these sets.
Let me know if the photos look anything like your issue, you are going to need a Mitsubishi remote in any case to adjust.
Jun 09, 2011 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I cannot correct convergence on my Mitsubishi ws55511
U know how to solder right?Tries these websites.Tv Repair World.com,Sopjimmy.com or Ebay.com.Just buy it with a instruction cd for tutoring.
Sep 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws55511 hd is projecting a distorted view on screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Double image on picture model # ws55511
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2009 | Mitsubishi WS-55511 55" Rear Projection...
How do you replace the convergence part on a Mitsubishi big screen tv Model WS55511? The new part has prongs on the bottom and I don't know how to attach them.
they have to be soldered in place after you de-solder the old ones. Radio shack has a de-soldering iron with a rubber bulb that makes this easy. Then solder your new ones in use a pencil iron 30 watt also available from radio shack. Use heat sink compound on the back of the ICs where they contact the heat sink. This compound is also a Radio shack item. Just be careful not to bridge any of the pins together with solder. Check your solder with magnifying glass before powering it up
Jan 31, 2008 | Televison & Video
Mitsubishi WS-55511 55" Rear Projection Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
