How do you replace the convergence part on a Mitsubishi big screen tv Model WS55511? The new part has prongs on the bottom and I don't know how to attach them.
Which convergence part are you talking about? I have a color problem on my Mitsubishi model WS55511. The green color is way out in left field.
Posted on Jun 05, 2008
  • 8,617 Answers
They have to be soldered in place after you de-solder the old ones. Radio shack has a de-soldering iron with a rubber bulb that makes this easy. Then solder your new ones in use a pencil iron 30 watt also available from radio shack. Use heat sink compound on the back of the ICs where they contact the heat sink. This compound is also a Radio shack item. Just be careful not to bridge any of the pins together with solder. Check your solder with magnifying glass before powering it up
Posted on Feb 01, 2008
Mitsubishi ws55511 error code 22
Blown capacitors on the DM board or the convergence IC is bad...
Jul 25, 2014 | Mitsubishi New Original WS55511 Remote...
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The pic is off there is bowing at the top and
Picture becoming distorted at the top/bottom of the screen is due to the convergence circuit going bad, and is a common issue with big screen projection TVs.
The convergence circuits will need to be repaired, which will generally require some soldering and ordering new parts for ~$75. If you want to get a TV technician to repair it then you will probably be looking in the region of about $300 for a repair.
Here is a link to repair guide for a Mitsubishi TV. Obviously a different model, but the convergence circuits are generally the same for most makes/models - this will give you an idea of the work involved to fix it: http://www.techlore.com/article/22530/DIY-Repair-Replacing-Convergence-IC-s-on-a-Mitsubshi-TV-Set/
Nov 17, 2009 | Sony KP-57WS500 57" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I cannot correct convergence on my Mitsubishi ws55511
U know how to solder right?Tries these websites.Tv Repair World.com,Sopjimmy.com or Ebay.com.Just buy it with a instruction cd for tutoring.
Sep 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Double image on picture model # ws55511
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2009 | Mitsubishi WS-55511 55" Rear Projection...
How do you install the convergence part on a Mitsubishi WS55511 big screen tv? The part has prongs on the bottom but I don't know how to attach it.
you must de-solder the output IC first. Then I would suggest that you remove the heat sink by removing the philips screws holding it to the pc board. you will find white heat sink compound on the bottom of the heat sink. clean this off and remove the output IC. put some heat sink compound on the new IC and install in in the holes on the pc board. be careful removing the solder on the pc board. I like to use solder wick. Install the new IC and solder it up as the old one was. remember to check the convergence in both analog and digital, as you have to converge both for it to remember the settings. Hope this helps. TV repair guy :)
Jan 31, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Convergence Problem?
Convergence problems are what you have possibly a pincushion error. Either way if you have to have a repair shop do the repair, you should look at replacing the old TV.
Jan 26, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
