Question about Hunter Fan Company 5/1/1 Programmable Thermostat
5 wire t-stat
I mix up the wires not sure which goes where yellow,red,blue,white & green.help
  • 8 more comments
  • gfanaya Jan 31, 2008
    hunter model 44660 connection as follows,G,Rc,Rc1,Rh,Y/O,W/B,Y1 and wires are Yellow,Red,Blue,White,Green
    old t-stat different from new one, user manual does not cover.
  • FtMill Mar 08, 2008
    replacing old thermostat and directions aren't too clear
  • paullambert Aug 18, 2008
    I have old T stat is a LuxPro and I do not know what wires should be connected with. Right now yellow connects to Y, Blue is to B, White is to W2, Red is to R and Green is to G. The instruction manual is not clear to what I should connect new Hunter T Stat to. Could you please help? My email is paullambert@verizon.net
    Thank you.
  • blond7299 Sep 28, 2008
    Hello, My name is Dee,I have the same problem my old thermostat was a York mercury,i replaced it with a Hunter 44660 programmable thermostat 7days , I have 5 wire with heat pump, and the manual is not clear on the connection, the thermostat does not show a Jumper? it state that is automatically changes between heat and cool, so I set the temp at 73f cool it switch over by itself to heat, came home and found it was 98f inside,Yes it was hot, just need a simple instruction on all the colors to see if I hooked it up correctly.Please help a lady out Trying to save money look like it will cost me more. thank you.. Dee
  • henrichss Oct 23, 2008
  • b_bertke Oct 28, 2008
    Don't know how to connect wire.
    hunter model 44660 connection are as follows,G,Rc,Rc1,Rh,Y/O,W/B,Y1 The wires I have are Red,Blue,White,Green
  • wlangley1979 Nov 08, 2008
    mixed wires up dont have manual to rewire need help please!!!!
  • pvmc_77 Dec 16, 2008
    york heat pump t-stat blinking #2 code Help
  • Goran Veletic May 11, 2010
    What unit to you have?
  • 43 Answers
Ups sorry :D see what is code in your area and than consult your user manual.
Posted on Jan 31, 2008
  • Goran Veletic Jan 31, 2008
    http://www.askmehelpdesk.com/heating-air...
    here is the solution with all credits to the original author :D
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 26, 2017 | Honeywell Heating & Cooling
I have a White Rogers programable thermostat I need to wire but my wires don't match up. The wires from my unit are blue, green, orange, white/blue band, white/green band
When you remove the wires from the old t-stat they should go to the same terminals you pulled them from. If R had an orange wire then the orange goes to R on the new t-stat. If that's not a good method, probably due to the style of old t-stat, then you need a tech. In order to wire it properly you will need to know what color wires are connected to what terminals inside the indoor unit. Normally inside the unit there will be R,G,W,Y,C where red-R, w-white, G-green, Y-to yellow or sometimes blue, and c-blue unless blue is used for the y circuit. We can use any color we want when wiring these units so honestly there's no way to give you a good answer. Work safe!!
Jun 21, 2015 | Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I have 5 wires red,white,green,blue and yellow, but i dont now how to instale those cables please show mi how do it.thank you
This is if you have gas furnace and central air conditioning.
Normally this is the way.
Red wire to R (or if your stat has Rc and Rh, wire to both of these
White wire to W
Green wire to G
Yellow wire to Y
Blue wire to C
If you want to check, before you connect to stat. Connect red and white (heat should come on)
the connect red and green (blower should come on) Normally yellow is for air conditioning and Blue is common DO NOT CONNECT ANY WIRE DIRECTLY TO BLUE, if blue is common it would short out fuse
Jan 26, 2011 | Heating & Cooling
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
There is five wires yellow, green, red, white, the problem that we a facing is to connect these wire into the honeywell theromostat RTH3100C1002-0916
yellow is the cool wire, green is the fan wire, white is the heat wire, red is the power wire. these stats should have a 1 letter icon ,r for red on stat y for yellow and so on ,make sure that Rc and RH are jumpered and install batteris if needed
Sep 29, 2009 | Honeywell Electronic Programmable...
Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Sep 20, 2009 | Heating & Cooling
I'm installing a Honeywell RTH7600B programmable thermostat and replacing a Honeywell T87F2873. The new one calls for a Red, Green, White, and Yellow wire, while I only have a Red, Green White and Blue....
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Jan 16, 2009 | Heating & Cooling
I have 5 wires, white, red, yellow, blue and green and am trying to install the Hunter programable thermostat model 44360. I am not sure which wires connect to what...help.
The standard code is red is power or [R] on your t-stat, yellow is cooling or [Y], blue is common or [C], and green is fan or [G]. This is standard across U.S.A. if the installer, installed it correctly. I as a rule of thumb look in the air handler to make sure the colors are correct. I always tell my techs. that elec. doesn't any color and this could you from burning up your t-stat. Plus, while your in the a/h you can make sure your blue common wire is connected. You will need this to run your programmable t-stat. If you are replacing a reg. t-stat then it might not be in use, but without it your running the t-stat on battery back up.
Sep 28, 2008 | Hunter Heating & Cooling
Air handler
This should be doable: First get pen and paper-start at the furnace, theres a group of 5-8 wires leaving the furnace anfd going to the thermostat and a group of 2-3 going to the condenser outside that all need to be identified and the location in the furnace recorded if your furnace has a control board simply right the letter and the corresponding wire color:and whether it belongs to the condenser grp or the T-stat grp.
Furnace
R-red-to t-stat
C-yellow to cond
Y-red to cond and yellow to t-stat
G- green-to t-stat
W- white- to t-stat
If you dont have a circuit board youll be doing the same thing but using the components rather than letters;
Transformer 24v- red to t-stat
transformer 24v com -yellow to cond
Red from cond connected to yellow from t-stat
fan relay - green to t-stat
gas valve - white to t-stat
K then go to you t-stat and simply connect the corasponding component or leter to the thermostat gterminal
Cond Furnace Thermostat
yellow com- blue -C or B
gas valve or w-white -W
fan relay or g -green -G
trans 24v or R -red - R
red connection to cond or Y on board -Y
Hope this helps.
Jun 12, 2008 | Quasar HQ2052UH Air Conditioner
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
387 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
