Question about Toshiba SD4990 DVD Player
DISC NOT LOADING
After pressing Play, the SD4990 just reads a flashing LOAD but will not play.
  • 6 more comments
  • ceedeath Feb 27, 2008
    CDs in the Toshiba SD4990 wont load. DVDs do, but not CDs or CD-Rs.
    I've tried to clean the disk using Scotch DVD/CD Laser Lens Cleaner Disk and even that wont load.
  • stanley19 Oct 11, 2008
    I have opened the top and the dvd is not spinning. It just sits there with the Load light flashing.
  • Anonymous Oct 18, 2008
    load keeps flashing even though i put the dvd in.
  • katiemack Nov 15, 2008
    mine just started doing the same thing!
  • Anonymous Nov 20, 2008
    Same thing happening to me.
  • cbscpa Jan 04, 2009
    When I put a dvd into the player, it just keeps flashing loading and nothing happens. I've had the machine for over a year and this just started today.
  • Anonymous Feb 02, 2009
    Same problem...this thing sucks
  • pete_0130 Apr 07, 2009
    Mine does the same thing to, but then says every disc I try is a "bad disc"- data disc or not... what gives?
    Champion:
  • 209 Answers
There are 2 reasons, your cd rom lens might be dirty and needs to be cleaned, you may use the lens cleaner cd. and your cd you are loading might not be supported by your cd rom, a different code could also one reason.
Posted on Jan 31, 2008
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Wont play movie
You may need to clean the laser lens.
Dec 13, 2009 | Televison & Video
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
DVD tray will not open
I had the same problem - unplug first- it is easy to undo all 6 small screws - open it up -plug in and then you can give it a little help to open it. It worked for me, BUT now it will open and close but not play the dvd.
Jan 13, 2008 | Toshiba SD4990 DVD Player
Will not play anything.
There is a rubber belt inside the loading mechanism, you should replace it by the new one. Cleaning the optical unit can be of great help also. If you need more info, please advice.
Mar 20, 2007 | Sony CDP-CE275 5-Disc CD Changer
Will play cd's but cant read dvd's - NO DISC appears
Could be that the lazer is faulty.try multizoning unit. switch on unit with NO disc inside. press enter,press 84269 and press enter again. unit will switch off.
Aug 18, 2006 | Samsung HT-DB120 System
Toshiba SD4990 DVD Player Logo
403 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
