Question about Panasonic FP-7735 Black and White Copier
How do I replace the drum cleanig brush
Thanks for all your help you guys rock! Now I need to replace the drum cleaning brush how do I get it out. I see it and I can see where it is. how do I get it out????
  • 105 Answers
Won't agitate drain or spin
When this happened to mine, firstly, the filter in the drain needs cleaned or replaced. Second, the brushes or bearings could be gone depending on the model. Get washing machine repair guy out, this is how we found out about ours, as our drum was a sealed unit stopping us getting to the smaller parts.
Jul 11, 2015 | Washing Machines
Missing Wii Rock Band 2 dongles for drum and guitar
Go to the nintendo site and go to the shop and repairs then there you go!
your guy for help,ElijahCruzEven kids can help :)
Jul 13, 2012 | Nintendo Rock Band for Wii
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
How do I replace the Cleaning Brush for the drum?????
why in the world are you replaceing the brush? In 25 years of copiers, i,ve never had to replce a brush. If its streaking on the copy, its the blade thats bad. only reason to replace a brush is if its broke,cause of a clog. just vacumm it out.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Panasonic FP-7735 Black and White Copier Logo
60 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
