This problem should be removed because:
Problem with Panasonic PT-50LC13 50 in. Rear Projection HDTV Television
The power light on our 50
The power light on our tv first blinks yellow when we turn it on, then changes to green and begins blinking faster, but the screen never comes on.
Solutions (1)
Lamp or Ballast Board
Suggested Solution (1)
TV won't come on
Model 62526. WHen I turn it on, the lamp(green) & status(yellow) lights begin to blink. After about a minute the lamp light stops. The...
When turning on the TV the green light on the
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another...
Unresponsive TV
The power light on our tv first blinks yellow when we turn it on, then changes to green and begins blinking faster, but the screen never...
Toshiba 62HM196. Original tv
Toshiba 62HM196. Original tv would not start up. Was indicated that is was the ballast. I purchased a used ballast and installed it. Now...
Add Your Solution
My PT-50LC Panasonic TV will not turn on. The...
My PT-50LC Panasonic TV will not turn on. The power led is flashing orange once each five seconds. The manual says...
replaced lamp on panasonic tv and now a black box...
PT-50LC14, replaced the lamp & now a black box across pictrue
When I push the power button, the indicator light...
I try to listen for any noises coming from the back but I don't hear anything that sounds unusual.
cant figure out how to remove lamp from panasonic...
gues its the lamp assembly that i need to get out since the lamp is inside it
See all Panasonic PT-50LC13 50 in. Rear Projection HDTV Problems
Fix-O-Meter
125
125 people viewed this problem
- 0 people are following this problem. Be the first!
Top Panasonic Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
