Question about Lite On (SOHC-5232K) (SOHC-5232K-BULK) CD-RW/DVD-ROM (Combo) Burner
Lite-on sohc-5232k problem
I have a lite-on sohc-5232k combo drive. I installed the latest driver (Nkoj) afterwhich, my drive stopped recognizing any type of cd/dvd inserted into the drive. I see the reader light come on, it flashes as if it's reading it, but then nothing happens. I tried uninstalling the drive and let my computer redetect the drive to no avail. I also tried cleaning the lens but my drive won't recognize it. Please help. Thanks
  • 1 more comment
  • Bobby-5 Feb 14, 2008
    My drive lite-on combo sohc-5232k recognize all CD ank works fine, but no recognize any DVD, it doesn't matter if it is Movie or data.
  • Anonymous Jan 08, 2009
    I updated my computers windows and now my computer doesn't have a cd drive in my computer at all ever. uninstalling and restarting the computer doesnt help either.
  • giannacl Mar 27, 2009
    I have a lite-on sohc-5232k combo drive. I had to reinstall XP because of a problem and now my CD rom can only reads, but do not burn. I install the drivers (nkoj) but still wont burn.
  • 43 Answers
Try system recovery if it is turned on, also you may try to unplug and plug back your drive from motherboard.
Good luck
Posted on Jan 31, 2008
When i open device manger it says that there is a problem with the driver for my Lite On Combo SOHC 4832K CD/DVD rom. I've tried uninstalling it and re-installing it no difference. I can't download a free...
Hi fonce linda,
You can find the Drive Firmware Update here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=pv-38120-1
You must be logged on as an administrator to install this update have not been logged in as an administrator that may be causing your problems.
Hope this helps, if not leave a comment and I will help you more.
Dec 26, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
I mite have deleted my lite-on combo sohc 5232k by mistake can you help to get it back plz
control panel administrive tools computer management device manager scroll to cd/dvd drives you should see either a red x or a yellow ! or a? right click to install drivers or
open up your computers side panel to access the lite combo drive unplug it then plug it in again from the electical lead
this should activate the found new hardware wizard then you might have to install the drivers for this device
hope this helps
Dec 09, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
I need software to install DVD. I lost de software. Mo.SOHC 5232k
Hello Mario,
I have tried to look for a direct link to the driver software you requested for on the website of LITE ON America and this is the link for it:
http://www.liteonit.com/DOWNLOADS/ODD/SOHC-5232K/firmware/CO52NK0J.zip
just click on the link, download and then install it for your LiteOn SOHC 5232k CD-RW/DVD Drive.
Once again the link is:
Hope I have been able to solve your problem.
Kindly let me know how it goes.
Goodluck and thank you for using fixya.
Dec 04, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Seen by windows as cd rom drive only
Check your device manager and look for flags or exculmation marks under the drive.
If none found, go to lite-on and download most recent drivers for the drive.
Nov 24, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
I recently bought a lite on sohc 5236k, unfortunately it didnt come with a manual so i am unsure of the installation and set up can you help dave
If its an internal burner, you have to open your computer case, remove your old drive and note the setting ont he back, the "jumper" will be on either M, S or CS. Select the same setting on your new drive and replace it inside the case. For step by step
http://www.pcguide.com/proc/physinst/cd-c.html
Oct 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
DVD Combo cannot detect CD
you will need to install a driver for this and make sure all components are connected
Mar 18, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Burner problems
First check if device is recognised in bios, if it is then you need to fixwindows. If you cannot see cd unit in bios then check that slave/master / cable bridge settings at back of cd are fine.In this case the fastest way to test your unit is to connect it as single unit with a tested ide cable on the computer, just to test it. On the other channel you connect the hd. Eventually switch channels and cables between hd and cd.
Feb 19, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Does not recognize CD
Could be the cd's not compadible, try a more expensive one.  This is a cd/dvd burner combo right?  If so how long have you had it?
Oct 14, 2007 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
LITEON DVD/CD-RW CAN READ DVD BUT NOT AUDIO/DATA CD.
I would suggest cleaning the drive with a cleaning dvd, $19.99 at most retailers. Or you can open up your computer and verify all connections to the drive are good, disconnect and re-connect to be sure. Hope this helps.
Sep 15, 2007 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Lite On (SOHC-5232K) (SOHC-5232K-BULK) CD-RW/DVD-ROM (Combo) Burner Logo
482 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
