Question about Olympus Stylus 800 / ? 800 Digital Camera
Write protection it wont let me take a picture, the screen is blue and it says write protection
  • cbach36 May 26, 2008
    Screen is blue and says "Write Protect". I read my manual cover to cover and cannot figure out what this means or why I cannot take a picture.
  • 105 Answers
Could be a couple things.
first: your memory card most likely has a slide switch just switch that back to the unlock mode
second:
second: from olympus guy
put the camera into play back mode. This is where you can see your picuters on the camera. Then go into the menu and try to go to card setup. This is 3rd tab. So hit ok hit right for mode menu. then hit down to you see card setup. Then hit right arrow 2 times and you will see formatt. Then go to yes and it will say caution somthing. and hit ok
Now if you have picuters on the card this will delete them so if you care about them you might want to think about data recovery. But if not try this and let me know.
"""I don't use the camedia software to download pics from the camera, neither do I use Xp's picture and scanner wizard. I simply plug my cam to the usb port and xp detects it as a USB mass storage device. I then copy the pics from the removable device displayed on My Computer window. Would you say that this method is not safe?""""
This is best way to do it i think. If you dont want to go into Cameida. The xp scanner camera wizard works good most time i dont know why it messes up some camera cards and its really random. One thing i would say. Formatt the card everytime you download your picuters. Not in the computer by right clicking on the driver, NEVER DO THIS!! will blow your card basicly. Do not delete pictuers from you computer with camera pluged it. Basicly most cameras us a diffrent file system the your computer. So that can start to mess things up. Just put the card into camera and do a format.
hope that helps.
Posted on Jan 31, 2008
Write protect on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 07, 2014 | GE T123 Digital Camera
Blue screen is black and picture very dark
What did you have before you replaced the lamp?
Dec 07, 2012 | JVC HD-52G886 52" Rear Projection HDTV
When i turn camera on to take picture it comes up with a blue screen and says write protect and wont let me take pictures but i can still use other functions,what does this mean?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 16, 2010 | Cameras
Write protect
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom of your computer screen?
Oct 28, 2009 | Olympus FE-210 Digital Camera
I have a blue and yellow shadows in my picture and when i use the perfect focus all the colors are in line except the blue.
Sounds like the STK packs are bad. Maybe change convergance amps along with protect fuses or low ohm resistors on the PCB
Oct 13, 2009 | Akai PT5598HD 55" Rear Projection...
TV screen Flashes blue and then shuts off.
When it flashes blue, are the flashes bright blue lines going across the screen with the picture in the background, if so, It sounds like the Blue tube or blue driver circuit is breaking down after a short period of time. If this is the case, the uPC that controls the set is detecting a large current drain on and is shutting the set off for protection, An engineers expert eye is required I`m afraid. Ian.
Jul 24, 2009 | Sony KP-65WS500 65" Rear Projection...
I get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Jul 23, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Camera says "write protect" and I can't figure out what happened.
my chager to my jazzcamer hdv178 dose not work where can oreder another one?
May 18, 2009 | Olympus Camedia C-160 Digital Camera
Cant take photos as it says the card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Mar 20, 2008 | Nikon Coolpix 4100 Digital Camera
Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Jan 29, 2006 | Toshiba 32A43 32" TV
Olympus Stylus 800 / ? 800 Digital Camera Logo
104 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
