Question about Canon PIXMA MP780 All-In-One InkJet Printer
Replace canon MP610 drive belt
I need to replace the drive belt on my brand new MP610 printer, because tubes from CIS jammed the print head and damaged the teeth on the belt.
Do you have an service manual/video/instructions for replacing it or for a similar canon printer. Thanks
Or can i just loosen n rotate the belt a bit, to position the damaged teeth where the printer head is not printing.
  • ankasa Mar 17, 2008
    error 43
Hola
Posted on Aug 28, 2008
  • 421 Answers
Http://www.tradebit.com/filedetail.php/3901080-canon-pixma-mp600-and-mp600r-service-manual
Will show you how to take the printer apart, basically the same as the 610.
Posted on Sep 21, 2008
My Canon MP610 have an error 6A00 what does it mean pls help.
It means the cartridge mechanism is jammed. It could be caused by dried ink, dried gear fluid or a paper jam. Open up the printer and give the cartridge holder a little nudge. If you see any foreign objects eg. shreds of paper inside, remove it.
May 07, 2011 | Canon MP610 Photo All-In-One Printer
Error 6A00
Hello and Welcome to FixYa!
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MP610 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
I hope it will be surely helpful for you. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Apr 19, 2011 | Canon MP610 Photo All-In-One Printer
Canon MP610 and it will not print or copy in black and white have changed cartridges and cleaned.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 06, 2011 | Canon MP610 Photo All-In-One Printer
Printer was working O/K last time I used it, turned it today and it tells me that there is a printer error and shows code A600. Have tried turning off and on as suggested and this has not worked. please...
Hello and Welcome
I am Angel Bird and i will be assisting you regarding the issue
The A600 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,It usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.The purge unit,called a spittoon assembly in an Canon, HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing,That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow, Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution was helpful for you. Please Rate my solution it if it helps you.
Thanks & keep usin FixYa
Mar 13, 2011 | Canon PIXMA MP610 InkJet Printer
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
I replaced the cyan ink cartridge. The printer accepts that the cartridge is full but prints with no blue. I bought another new cartridge and have the same problem.
It sounds like you need a new print head. You can find them online for around $75.00 each. I've had very good luck with Precision Roller. Do a google search for "canon mp610 print head".
Feb 06, 2010 | Canon MP610 Photo All-In-One Printer
I have a canon mp610 printer. the yellow coulor is not coming through, any ideas , otherwise printeris great
The print head is clogged.Try unclogging with cleaning process in maintenance mode.If not help you need replace the print head.It's part number is QY6-0067
Nov 08, 2009 | Canon MP610 Photo All-In-One Printer
To buy or not to buy canon or compatible inks
The generic inks don't hurt your machine at all, but I find that the colors arent as good and bright as the Canon inks.
Jul 03, 2009 | Canon MP610 Photo All-In-One Printer
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
Yes vintos after long storage problems with the printer heads may arrise.
Thermal changes from being in storage can cause the printer heads to dry up and fail.
DO NOT USE ALCOHOL or other solvents in an attempt to clear the printer heads.
1. Attempt to change ink cartridges , this may clear the issue.
If that fails , you may be forced to change printer heads at that point.
Link to Printer Trouble Shooting. ( generic steps for all printers )
http://www.duxcw.com/digest/Howto/troubleshoot/print/index.html
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
728 people viewed this question
old marine
old marine
