Question about Gateway M675XL Special PC Notebook
Gateway M675XL Power light comes on, no screeen. do I need a new Mother Board or a new Hard Drive. A couple of times it came on, if I let it set over night, Had the Hard Drive tested at Best Buys the other day and they said it test out to be ok. Called Gateway Tech and he said it sounds like the Hard Drive is bad. Now don't know what the heck to do. do you have any Ideas as what to do. Thanks
  • wondering8 Jan 31, 2008
    Ok, must be Motherboard, any idea were to find a good buy on one and are they difficult to install. Thanks
    Ok, Thanks a bunch, guess I'll go shopping.
I had the same problem found to be a bad memory slot on my motherboard. I would suggest removeing one memory stick and restarting the computer. Swap slots if it doesn't work. I don't have any other idea if that doesn't work
Posted on Feb 22, 2008
  • 43 Answers
If you see nothing and hear nothing and hd is not spining motherboard.
Posted on Jan 31, 2008
  • Anonymous Jan 31, 2008
    I have no idea if you want to buy a new one it is half of the price of new laptop so it is not an option, and if you get used it may die again so I would recommend getting new laptop.
6ya staff
SOURCE:
Unable to format the hard drive
Need more info? Is the HDD installed? The primary drive? Are you installing a OS?
Feb 05, 2013 | Gateway M675XL Special PC Notebook
Tech says i need new motherboard computer won´t turn on
Before you buy a new mother board, (the L300D-13S board is around $185 from China), remove your battery, leave it for about 5 minutes. Use only the Mains power supply and see if it will switch on.
Fit the battery, plug in the Mains Charger and see if the battery charge light comes on. If it does and it won't give you a screen or flash the hard drive light or power up the hard drive, then I am inclined to go along with a replacement Mother Board.
The laptop has to complete the POST and if it doesn't that usually points to Mother Board problems.
Were you trying to upload a newer version of the BIOS before it failed?
Good luck but check ebay and beware there are some really dodgy frauds out there.
Oct 20, 2010 | Toshiba Satellite M35X-S1142...
Satellite M45-S351 locks up won't shut down. First thing, may lap top would not shut down so we had to use the power button, then after some time 2-3 the unit decided not to boot up. we copyed the hard...
I think it is a prob with the mother board.........no need t change RAM or hard drive........they dont cause this type of prob. Ur mother board is not accepting the shutdown command.
Try the following command in command prompt:
shutdown /s /f
May 23, 2010 | Toshiba Satellite M45-S351 Notebook
Gateway MT3421 Laptop start-up Issues
Start by removing the battery completely, and plugging the power cord into the wall socket. If the power indicator light comes on at the converter on the cord, your power cord is fine. Then plug the power cord into the computer. If the computer starts up you know the power cord connection on the computer is not the problem. Now witrh the power cord plugged in install the battery if the needs charge light comes on you probably do need a new battery as the cells often do go dead after a period of time and wont hold a charge, this will cause the LCD screen to go black or gray, but NOT BLUE. Borrow a friends monitor and plug it into your computer as an external monitor and press the function key to toggle to external monitor. Now try to restart, if screen shows activity you can atleast check out your computer. You may want to test your connections andf then itry placing your hard drive into another similar computer and see if the same thing happens, if it does your hard drive may have a failure. You can transfer all the info from your hard drive to an external drive through a patch cable available online at circuit city for between $7-25. The two that are most useful are the CTG Laptop to IDE Hard drive adapter item C184-17705 and the Ultras USB 2.0 to IDE/SATA cable adapter item UL740112 depending on what type of hard drive connections you have. Once you transfer your information to an external you can try to restore your computer using the original system restore disk that came with the computer. Set to boot from disk and away you go... If this does not work you may have a bad hard drive or possibly the mother board. If the mother board is bad you may want to just keep the computer for spare parts as it might not be worth the cost of repairs. If it is the hard drive you can get good quality Hitachi Harddrives reasonable (for less than $90 for upto 600 GIGS on line again at circuit city without any shipping cost and will have it within a couple of days.
Hope this helps.
Feb 08, 2010 | Gateway MT3422 RTL Notebook
Gateway 510X H Desktop will not power up
Yes, definitely. You need to change your power supply.
Jul 23, 2009 | Gateway 510 X (10272197) PC Desktop
Gateway 830GM power
Could be power supply, unplug every thing from the board, remove all drives, cards everything but the mem. turn it on, if you get some beeps, add your Hard drive. The power supply may not have the guts it take to run all the peripherals it used to, this test will tell you if its the board or power supply.
Jul 15, 2009 | Gateway 830GM PC Desktop
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at [email protected] or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Gateway gt motherboard failure
Yeah that's right. Change/replace the power supply. Yet, you have to test the power supply's conditions if it still works alright. since you are suspecting both motherboard and HDD first. If yellow light comes and no action to the whole machine then that must be something in the motherboard. Before you finally follow your decision to change the power supply, check the motherboard. There are capacitors and examine if it didn't bloat. If it does, just take out the capacitors with exact microfarad and voltage specs or change the whole board. And granting though that the supply is bad, there must be some electric signals that have caused to the mother board which will eventually, at the end of the day, you encounter the same problem with it.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
I have a Gateway computer that is 10 years old. I
1- you have to change your power supply and you have to change your hard drive to one biger than you have but it must be IDE.
Apr 06, 2009 | Gateway 310S (2900621) PC Desktop
Open Questions:
See all Gateway M675XL Special PC Notebook Questions
Gateway M675XL Special PC Notebook Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
