Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Overclock how can add more speed to my processor using overclock
Incrise ram and delete temp and remove disk top iconns
Posted on Jan 31, 2008
6ya staff
SOURCE:
How to add core volatge? AMD ATHLON LE-1620 on biostar motherboard?
Well, when overclocking, one doesn't usually change the core voltages until _after_ manipulating the bus frequencies, core speeds, and ratios. One should understand manipulation of frequencies before messing with voltages because manipulation of voltages can lead to _fried_ components. Usually one can get a decent overclock just by manipulating the frequencies. Here is a _starter_ website:
http://www.tomshardware.com/reviews/phenom-overclock-athlon,2161.html
Research, research, and research some more before trying to overclock.
Here are some required tools:
http://www.cpuid.com/softwares/cpu-z.html
http://www.alcpu.com/CoreTemp/
http://files.extremeoverclocking.com/file.php?f=103
http://www.cpuid.com/softwares/hwmonitor.html
There are a lot more tools out there, these are just the ones that I use.
I'm running an Intel E8500 (3.1 Gz.) at a stable 3.5 Gz. with _no_ voltage changes. That's not a huge OC, but it's running at E8600 speed and the E8600 costs $100 more than the E8500.
Feb 26, 2011 | Computers & Internet
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
    Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
    But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
    Sirwriter
    Nov 05, 2009 | Intel DG31PR Motherboard
    Problem in overclocking my Processor.
    1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
    2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
    Mar 30, 2009 | Intel Computers & Internet
    How to overclock a pentume 4 processor
    Increasing of FSB (processor clock) from 10% up to 15%.
    from 1700Mhz you can get 1850 Mhz.
    from 2400 Mhz you can get 2640 Mhz
    from 3000 Mhz you can get 3300 Mhz
    but not all mater board allow this do.
    Mar 07, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Need 2 install the fastest PIII processor possible on CpxJ650GT
    you obviously seem to have the adequate knolledge so why dont you overclock it...
    overclocking used to be a touchy subject but know its undrstood that that it creates no problems..the chips are designed to be overclocked,in fact overclocked should now not be the trerminology for it ...it was called overclocking cos then it wasnt natural and created unstable systems ..now it is merely enhancing .
    Jan 24, 2009 | Computers & Internet
    How do I overclock a Celeron 733mHz PGA370?
    You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
    Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
    Who to overclocke my motherboard'z FSB or my processor?
    Hello.
    It is not save for your system making it work faster by overclocking it.
    Some times it works fine just using the right cooling methods, but some times its leads to system freezes, crashes and even to permanent processor damage.
    So i advice you to keep that in mind.
    If you want to proceed anyway.
    - In newest computers you will find an option to set the processor speed to automatic( system recognize the cpu speed) or manually, in the last one you hve to set the RATIO( Processor speed divided by FSB speed), this means:
    - The FSB of your P3 Motherbord (133 Mhz) x 7.5(ratio)= 1Ghz
    - In older motherboards the speed option is set using jumpers
    configuration in the Board, inthat case you will have to use the motherboard manual( some boards have printed tables) to show you the config.
    Note: if your motherboard doesn't show you the RATIO you need is because it doesn't support that speed.
    Good look.
    Jul 04, 2008 | VIA C3, 800 MHz (VIAC3800) OEM / Unboxed...
    OVERCLOCKING
    The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
    One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
    Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    How can I overclock my 166mhz classic computer?
    Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
    Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
    Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
    There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
    Here's a pointer:
    http://www.extremeoverclocking.com/
    PS: Search google for "overclocking" and you should get a lotta links to work with.
    Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
    51 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    Ekse
    Joe Negus
    Joe Negus
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
