Question about Dryers
ELECTRIC DRYER SMELL LIKE GAS - Dryers
  • Anonymous Mar 11, 2009
    I have the same problem. And yes, I did just stain some woodwork. So, how do I get rid of the smell in the dryer?
  • 240 Answers
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Posted on Feb 02, 2008
To stop gas smell after opening dryer door
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag pygt344aww gas dryer not heating and has burnt smell
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer starts to smell like gas when running. Just started recently
Hi, the most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 19, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer isnt getting hot.smell a little burning smell.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 19, 2010 | Frigidaire Dryers
No heat gas smell
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
697 people viewed this question
Top Dryers Experts
