Question about GE GSH25JFR Side by Side Refrigerator
No water or Ice
The unit is making Ice but will not despense it. on very few occasions the water will work but when you try to get ICE nothing happens except the light on the icemakes gets dim. This all started yesterday.
  • 1 more comment
  • jcronin1 Jan 31, 2008
    I was able to turn the unit by hand. I did not see any ice build-up.
  • Anonymous Jan 31, 2008
    My Ge has same problems
  • jcronin1 Feb 01, 2008
    After serching the internet I found out that this is a common problem, it was the motherboard which GE came out and replaced at no charge.
  • 28 Answers
Chances are your waterlines and motor are frozen, which indicates you may have a leak somewhere, causing ice build-up
Posted on Jan 31, 2008
6ya staff
SOURCE:
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
Not despensing ice
Make sure the ice bin is pushed all the way in position. Also make sure you don't have a big clump of frozen ice blocking the auger and keeping it from working.
It is a good idea once in a while to take the ice bin out and completely wash and clean it out real good.
Jul 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
The door ice despenser is not working. It makes
Make sure that the bucket is pushed in all the way. If the motor is running the screw should be turning. I would also take the bucket out and try to turn the auger by hand to make sure it is turning free.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice,...
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Jul 22, 2009 | Refrigerators
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Will not despense ice through the door
could be a few different things, here are a few:
1) blockage in your freezer door where the ice drops in
2) the metal spiral in your ice tray that pushes the ice toward the door is frozen in place by ice
3) the motor that runs the metal spiral is not working
4) you have a bad circuitboard
Feb 20, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
GE GSH25JFR Side by Side Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
