Wire connectors where do the 3 plugs go in the back of the dvd player--one is yellow, one is red, the other is white
  • 871 Answers
Yellow = video
red = right sound
white = left sound
fixya!!!
Posted on Jan 31, 2008
How do I hook up this DVD player to my 60 inch Westinghouse model #VR-6090Z ?
If your DVD player has HDMI, use it. If not, you'll need to buy a cord for it. Look on the back of the TV and the back of the DVD player. There should be colored connectors on each one. On the TV, it will be an input. On the DVD player, it'll be an output. There will be either 3 connectors or 5 connectors on the TV and DVD player. You'll need a cord with either 3 connectors on each end (red, white, yellow), or one with 5 (red, white, blue, green, red). Once you figure out which cord you'll need, buy it from any store that sells TVs and hook it up. The link below has pictures
Video Connectors Tutorial Hardware Secrets
Feb 02, 2015 | Westinghouse Televison & Video
I bought a used Integra DVD player without any cables hooked to it. How many cables do I need and where do I plug them in?
The most basic connection is the 3 wire RCA cables with the Yellow, Red, and White ends, that connect the VIDEO, AUDIO LEFT and AUDIO RIGHT from the DVD player to the TV.
Plug the 3 cables into the corresponding colors on the VIDEO OUT and AUDIO OUT connectors on the back of the DVD player.
Then plug the other ends of the cable into the corresponding VIDEO IN and AUDIO IN connectors on the back of your TV.
The yellow cable is always the VIDEO signal and the red / white are the AUDIO left and right.
Then to watch the DVD player on your TV, just switch the TV's INPUT MODE SELECTOR option to VIDEO 1 or whatever label your TV has for the rear inputs.
That should be it.
There are other ways to connect the two devices, but that is the simplest and cheapest.
Thank you and good luck.
Apr 19, 2011 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
DVD Player S99
just use yelloew out and red white for sound left right those red whites are into tv input on back 1 or 2 yellow in yellw for video red in red for right sound white for left sound then turn on dvd player use tvs remote select input 1 or 2 thats it hit play
Mar 13, 2008 | Amphion Mediaworks S99 DVD Player
Need Help Setting Up DVD player to an old Zenith Television
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Feb 28, 2007 | Zenith B25A74R 25" TV
50 people viewed this question
 Grubhead
Grubhead
