Question about Archos 605 WiFi Digital Media Player
Archos 605 wifi 30 gb
Screan say,s recovery (code 108)
  • Anonymous Jan 10, 2009
    its exactly like that and then when i clicked okay it keep loping to teh same error and never stoped, i couldn't turn it off so i formated it, it was the only way...
    need help!
  • Painshadow Jan 10, 2009
    the same error and never stooped, i couldn't turn it off so i formatted
    need help!
Ave got same prob mate tried to download the firmware as red on the archos site in questions and answers fairly helpful but my computer does not put the archos on my desktop for me to transfer the files rang archos in holand apperently it means it is faulty and i am n the process of sending mine back advise you o rinng them on the 02 n0. that came with the item goodluck
Posted on Jun 09, 2008
207 error code
Download the latest firmware for Archos 605 WiFi to your PC.
Connect your 605 to PC and copy the film across and unplug 605 from PC.
I take it you have tried to update it and this happened.
It has happened to others too, they redownloaded and tried again and it worked.
Hope this helps, if it does then reply here please.
Aug 30, 2012 | Archos 605 WiFi Digital Media Player
My archos is showing "error code 108" on the
contract your manufacturer about replacement as there is no way to fix this on your own
Jun 04, 2011 | Archos 605 WiFi Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
Code 108 shows on archos 605
The archos 604 is a portable media player. It is not a PC. The Archos 605 WiFi runs embedded Linux on an ARM processor.
Here is a reprint of someone who solved this problem:
i just got my Archos 605 and when accessed the content portal it said i should update my firmware. when i said OK i got the message it faild connecting to the server and my archos froze.
after restarting it i'm getting the Recovery code (108) i tried to repair disk and format disk but both asking me to conncet to the PC and update the system. the problem i cannot conncet to the PC (i don't see the HD) and don't know what to do.
i managed to solve the problem, if you encounter same problem this is what i did:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. put the firmware update file directly on the root drive
6. click repair again on the archos and done.
now it should recognize the update file and perform the update
it worked for me
Oct 19, 2008 | Computers & Internet
Archos 605 WiFi Digital Media Player Problem: Archos 605 Recovery code 108
This is generally due to failed firmware updates, etc....here is something to try that has worked for some others:
2. click on repair
5. download firmware from archos website and put the firmware update file directly on the root of the archos drive
I've been told this does not always work on the first attempt, so give it a couple of tries if the first attempt fails.
Oct 16, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 parental code
i got the same problem, somebody help us please?
Mar 29, 2008 | Archos 605 WiFi Digital Media Player
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
114 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
