Question about Maytag MAV7200 Top Load Washer
Washer filled and died
I need some help with this problem. I have check and there is no inline fuse. There is power at the receptacle. If you move the dial and pull it out to start at any position, it does nothing. It acts like there is no power at all. Is there another fuse hidden somewhere or ???
Thanks for the help.
Bill
    Sergeant:
  • 226 Answers
Check for the wirings at the back panel of your machine.
Posted on Jan 31, 2008
  • 871 Answers
Hi there
you have to check the dial housing because the cause may be probably there, if there is power in the receptacle and whenever you start dialing, it wont start...if you still couldnt find the faulty part. if still in doubt, have it serviced instead. hope this helps...fixya!
    Genius:
  • 3,422 Answers
Some Maytag models have a fuse in the lid switch, but they are the only brand that does have one. since your washer is Maytag, then I would highly reccomend yo to check the lid switch, as most machines will nor run if it thinks the lid is open.
Good luck,
Dont forget to rate me as fixya..
    President:
  • 1,314 Answers
Try putting it on drain if it works there replace the pressure switch
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
Circuit board
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 16, 2008 | Maytag MAH6700AWW Neptune Front-Load...
C330 will not power up when plugged into power receptacle in car
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+STREETPILOT+C330&Show=ExtInfo I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Jul 11, 2010 | Garmin StreetPilot C330 GPS Receiver
No power
Does the receptacle that the washer plugs into have power? Check the breakers or fuses.
Jun 24, 2010 | Kenmore 22422 Top Load Washer
I have a minn kota 42pd/c. boat shop installed inline fuse between new 27 series battery and socket where we plug the TM in at front of boat. we blew 10amp fuse, then a 25amp fuse right away and eventually...
It is needed. I usually install 3 amp fuses. It sounds like you have a short somewhere. I would trace the wiring and make sure it did not get the sheath cut and is possibly contacting the boat. I always install a fuse and that eliminates the threat of a fire. There is a reason that the fuse is blowing and if you remove it then you move the problem straight to the battery and you will most likely see smoke. Also if you dont install the fuse the equipment factory warranty will be void. You really just need to check out the wiring carefully. If there is no problem with the wiring then there is a problem with the unit and should be exchanged.
Jul 27, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Maytag Stackable W/D
well htere is a fuse, its located right behind the washers front panel on hte right hand side. its an inline fuse( you can find at hardware or auto part store FUSE (250V 1A) , but this would stop all operations not just water fill. With the front panel off you can "see" through the machine to the filll valve and check it for poower when the "fill" is selected, I would point to a bad water valve or even a faulty prssure switch( not allowing power to the valve befoer condeming the timer.. the pressure switch is also located on the front rail by the fuse assembly anbd will have a plastic'rubber tube connected to it, i would disconnect and blow through the tube for possible obstruction.. ( if the pressure switch is satisified., the machine will think there is wate rin the machine and therfore wont allow anymore to enter.
Dec 27, 2008 | Maytag LSE7806A Top Load Stacked...
Ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Feb 15, 2008 | Washing Machines
Maytag MAV7200 Top Load Washer Logo
147 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
