Main seal I have a GE profile washer, 7 years old, leaking at main seal. Is this difficult to replace? I have heard that I will need to replace the tub seal, locking ring and hub nut. I can't see where the bearing(s) are/is. I assume these need replacing as they have been wet and rusty for a while and are noisy.
  • 240 Answers
This is a pretty tough job to do on your own, but can be done. First step is to remove the front, then the top. Remove the rear cover plate under the console, and swing it out of the way. Unclip the top ring and remove the four suspension dampener straps, remove the top ring. Reach under the agitator, and pull up with force (dont hit yourself in the head or face with it, hurts for sure...) until it pops off (agitators on GE's just snap). Sometimes these can be a real bear to get off, so dont get discouraged. Sometimes you can put a peice of small rope or line under it and jerk it up. After you remove the agitator, you will see the drive bell. Remove the bolt on top of the bell, and once again, try to pull the bell up and off the shaft (once again, a real bear in some occasions, rope trick or puller also will work here). Once you remove the bell, the good part starts. Most of us repair persons have a special spanner tool for that nut your looking at. I believe it is a 1 7/8" nut. This nut is REVERSED THREADED, which means to remove you will spin it clockwise. These spanner nuts can be very, VERY difficult to remove. A lot of WD-40 and time. Most of the time you have to bang them off with that special tool and a hammer, but you may get lucky. If you do get that nut off, you can remove the inner tub. Be sure that the metal drive hub bolted to the bottom of the inner tub is completely tight all the way around. GE units have a very bad habit of those screws backing out and the drum getting loose causing major league noise. Now that you have removed that, you need to remove the outer drum. Remove the wires from the motor, etc. Unhook the 4 suspension rods and plastic clips by pulling the bottoms down (spring loaded) and removing them from the frame. Unhook the tub to pump drain hose, tilt the entire center section top towards the back, and swing the unit out from the bottom. Remove the outer tub by removing the hold down screws. Your seal will be in the bottom. Just pop out and replace. Here are some diagrams that might help you out.
Cabinet and Top:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET%2C%20COVER%20%26%20FRONT%20PANEL&titleID=00002&
Drum, Agitator, Basket:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20BASKET%20%26%20AGITATOR&titleID=00003&
Drive Componants, Suspension Parts:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=SUSPENSION%2C%20PUMP%20%26%20DRIVE%20COMPONENTS&titleID=00004&
Good luck, and let me know how it comes out, or if you need anything further. Good Luck!!!!!!
Posted on Feb 03, 2008
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Feb 15, 2010 | Washing Machines
I was looking at a 5 year old whirlpool full sized thin twin stack washer/dryer and the complaint was that it was leaking intermittenly. I could never get it to leak while I was there until yesterday when...
well i personally have not heard of this before.did the speed of the agitation change with the level of the water.it makes sense because the blades are larger on the bottom of the agitator.with clothes in the washer this should cut down on the water splashing.
Jan 24, 2010 | Washing Machines
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Siemens Siwamat 2105 washing machine leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE commercial washing machine
During fill only
All the time
During fill only
All the time
Oct 24, 2008 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
Washing machine leaks when not in use
During fill only
All the time
During fill only
All the time
Apr 29, 2008 | GE WWSR3090TWW
Leaking Machine from underneath
During fill only
All the time
During fill only
All the time
Apr 14, 2008 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
732 people viewed this question
Top Washing Machines Experts
