Question about Radio Communications
Not receiving properly
My CB picks up better is the PL259 is only inserted, not screwed onto the back securely. The antenna is a trunk mount K-40. I have pulled the antenna off again, there is no broken coax. I also ran a ground wire from the mount to the chassis, but this did not help either.
  • 204 Answers
Pitcrew, does the noise go away when you screw the pl259 down tight? Find someone talking on a channel and do the PL test again and see if their signal disappears when you screw down the PL. Have you done an SWR test yet? Is this a fairly new antenna? If this problem came into my store, the first thing I'd do would be an swr test, the second would be to test with a volt/ohmeter from the center pin on the PL to the metal stinger to make sure there is a connection.Then check from the trunk mt to the outer ring of the PL for connection. Now, if you check from the center pin to the outer ring of the PL you should not have connection! If you do, the coax has a short in it,,,
Is this mounted on a trunk of a car? Sorry for all the questions, but there are so many different things it could be, and I'm just trying to narrow it down for you. Hope this helps some, let me know,,, Mechanic
Posted on Jan 31, 2008
Can i install a ham radio onto my gl 1800
Being a Ham Radio operator for more years than I care to admit, and starting to ride longer trips by myself, I decided to put a 2-meter FM Ham Radio on my 2006 Gold Wing. The advantage to Ham Radio is that it?€™s very possible to transmit over 100 miles using a repeater system. I thought it would be good company on my solo rides.
I had a similar set up on my GL1500, but my new GL1800 offered a unique set of challenges. Shallower pockets and more electronics caused transmit and receive interference, which all had to be worked out. I decided to mount the radio near the handlebars and just put it away in inclimate weather. Also, each time I stopped the radio would have to be removed to prevent theft.
First came the antenna. I took apart the am/fm radio antenna at the top and removed the cable. This was just a matter of driving out the drift pin. I took a double SO239 connector (a barrel) and, on my grinder, started turning half the connector until it just fit inside the bottom section of the am/fm antenna shaft. To this connector I soldered 10 feet of RG8U coax.
Before inserting the connector I drilled and tapped the holes from the drift pin to 8/32 so I could use a couple of small setscrews to secure the connector in place. The bottom half of the antenna holder is stainless steel so it is plenty strong. Then I ran the coax under the seat, top shelter, into the left fairing pocket, and up the handlebars. Cutting off the excess cable and soldering a PL259 connector on the end.
I chose a Diamond NR-770RA antenna. This antenna works great with little or no ground plane, has a PL-259 type base, and folds over in the middle like the stock Gold Wing antennas. It even looks a lot like the Gold Wing?€™s CB antenna.
Under the seat I installed an antenna combiner for the CB and the am/fm radio. That way the CB antenna serves both radios. These combiners are available on the internet. I tuned everything in using the tuning screws on the combiner and my SWR bridge.
I mounted my 2mtr radio on a Ram Mount. I fabricated a small custom bracket for an external push to talk, and a scan button. From the mike connector I picked up speaker and microphone signals. A single throw/four pole switch and I was able to switch from the bike?€™s regular cb/stero to my Ham Radio.
This project took about two weeks to work out all the kinks. The installation is clean, safe and works well. Cost with do-over, but not counting radio and antenna, was about $50.00.
Oct 24, 2017 | Motorcycles
Red lights come on ex and antenna come on when I key up the cb radio and the awe meter doesn't move
Sounds like high swr. If using a mag mount antenna; check for a proper ground by cleaning the antenna base and the place where you put the antenna. Any other antenna; check the place where the whip goes into the coil at base of the antenna. Make sure that antenna has good ground. Check continuity of the pl259. Make sure there is a good connection and no opens or shorts. Hope it helps.
Tom
Jan 13, 2013 | Cobra 29 LTD CB Radio
CB Antenna Warning Light
Sounds like bad SWR. Check antenna ground. If mag mount, make sure mag and whe you put it is very clean. Check antenna where whip comes in to coil or base. Check pl259 with vom for continuity, open or shorts. This will probably solve the problem. DO NOT TRANSMIT WITH HIGH SWR. YOU CAN BURN OUT POWER TRANSISTOR. HOPE IT HELPS.
Tom
Oct 20, 2012 | Cobra 29 Lx Full-featured Cb Radio
Swr on channel 1 and 40 are over 3, what can I do?
Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
Jul 15, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
The light for high swr keeps coming on. replaced antenna and coaxle. how do i go about lowering the swr. is there a nob or switch for this. thank you
You cannot lower the SWR via the radio. it has to do with the antenna. The length of the antenna is essential to transmitting properly. It must match the transmitting frequency.
To check SWR tune to ch 20. Flip the meter switch to CAL. Key the radio without talking into the radio. Turn the CAL knob up until the meter needle is at the CAL mark. Unkey the mic. Flip the meter switch to SWR. key the radio again, and the meter will show your SWR. We already know it is high because you are getting antenna warning, but we will have a base line now to work on.
What you did was calibrate the meter for that channel. that is necessary to check the SWR. So you must calibrate for each channel you check.
You should at least be under 2 swr. Ideal is 1.5 or under. the lower the better.
If your SWR is high, your antenna is either too long or too short. To find out here is what you do:
Check the SWR on ch 1 and ch 40 calibrating for each channel. Compare the difference of the SWR between 1 and 40. If the SWR is higher on 40 then 1, your antenna is too long. If your SWR is higher on 1 then 40 your antenna is too short. All CB antennas have a way to adjust the length.
If its a mag mount, its usually a set screw you loosen to raise or lower the whip. Fiberglass antenna's usually have something under the cap at the tip to adjust. It will either be like the mag mount, with a set screw and a small rod to raise or lower it, or a screw, that you screw in or out to make it longer or shorter.
make small adjustments. 1/8th or a 1/4 of an inch at a time. Each time you make a change, take an SWR reading on 1 and 40 again and compare the difference. The difference should be getting less. Do this until there is very little or no difference between 1 and 40.
Then you go back to 20, because it is the center channel and check the SWR there. It should now be low. If you did a good job it will be under 1.5 and you are good to go.
Aug 07, 2011 | Galaxy Radios DX-93T Base CB Radio
Cant get swr's to come down
this could be alot of things but you never say what antenna you are using ,please check coax with multimetre for short,check pl259,it might just be the pl259 but check it out also if you are using a coil loaded antenna check for breakage along the coil goodluck
Dec 02, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I can't seem to get any reception, just noise.
It mostly depends on your antenna location and how far away you are from other radios. The receive gain can be turned up in most radios. I do it here all day long. dodgem250.com
Apr 09, 2010 | Midland 4001 40-Channels Base CB Radio
Have not used my cobra for some time ...sine someone need my K40 antennae more than me. Just put it back in service with a new magnet mount 36 inch - can send and receive in USB and LSB ....can here in the...
Center the antenna on the vehicle, then check the SWR on channel 1 and channel 40.
with the switch in CAL position, key radio and use the swr/cal knob to set the meter so the needle is just touching the end of the red area on the right-hand side of the meter.
Once calibrated, unkey and switch the switch to SWR and key up again. The lower the reading, the better. If the SWR is Higher on 40, the antenna needs to be shorter.. if its higher on 1, then the antenna needs to be longer.
if it dont transmit period on AM, then there's an internal glitch :)
Jan 24, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra cb brand new and cant get it to work
get your swr checked by a cb shop. 90% of all cb problems are a poorly or not tuned antenna.
Sep 15, 2009 | Cobra 29 LTD CB Radio
I am getting high swr readings on my base station antenna. It is a 102'' whip and I don't think I have it connected properly. I connected the center copper wire to the antenna but did nothing with the...
what i would do is go and buy a real cb antenna mount like a mirror mount and get a peice of sheet metal and screw the mount to the metal and screw that to the roof or side of the house and you should buy a spring that will also help with the swr and if you by the mount you can just screw on a standard pl259 connector
Apr 15, 2009 | Radio Shack Radio Communications
Radio Communications Logo
125 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
