Question about GE WCVH6260F Front Load Washer
Ge front loader will not drain
How do i replace the pump?
    Genius:
  • 1,003 Answers
I DONT THINK ITS THE PUMP BUT IT SOUNDS LIKE A BAD control BOARD OR WATER OUTLET SOLENOID
Posted on Jan 31, 2008
My front loader will not spin but runs on every other cycle
I had the same problem. Check the filter, I have a GE front loader and it is located behind the front panel under the door.
Removed the baby's socks and haven't had any more issues.
Jun 23, 2012 | Frigidaire ATF6000ES Front Load Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
I cleaned the lint tray or catcher from the the front loader washing machine and the water still won't drain could the pump be out?
If there was a lot of junk in the catcher some of it may have moved to the drain hose.
Other than that, the drain pump is the most likely suspect here.
Apr 19, 2010 | GE WSXH208A Front Load Washer
I have a GE Harmony top loader washer all digital. My washer will not drain throught the drain hose. I have to lower the hose to the floor for the water to come out any ideas
Your pump might have something in it. I got a shoestring out of one the other day. Remove the front panel and inspect the pump.c8963d3.jpgbottom right of the photo is that clogged pump, The top does not pop up. The front panel comes off.
Mar 17, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Washer will not drain GE washer
If you have a top loader, try this.
If it agitates but doesn't spin or pump, it could be that your pump is seized or something is stuck in it. The agitator is operated by a different motor. Turn OFF the power. and remove the front vertical panel by inserting a drywall knife in a the top right about 4" in from edge at the joint 1" down from the top, push the clip back to release that corner, get another knife and do the same to the left top corner, the pull the top of the front panel and swing towards you, then lift off and remove. Discount the two hoses to the pump, one from the drum the other that goes to the back. Be ready for a considerable amount of water to come gushing out, use a hose to direct to a floor drain. Check to see if something is stuck in the pump or the hoses, remove it. Check to be sure the impeller spins. If you found something restricting the flow or pump, remove it and re assemble. If the impeller won't spin easily, then you need a new pump.
Remove blockage in the pump. Re-assemble and test.
Nov 01, 2009 | GE Washing Machines
I have a GE WSX208H FRONT LOADER = WET CLOTHS
Pump you are correct. This company should tell all of us that there is a hidden drain plug that needs to be cleaned out every so often so that we do not burn the pumps up on these front load machines.
Jun 15, 2009 | Washing Machines
My GE front loader does not drain
Look for the pump, take the hoses off it and check for clogs. Have a bucket ready to catch the water. Watch the pump while the machine is running, make sure it is spinning.
May 01, 2009 | GE Washing Machines
Ge front loader washer wsxh208a
remove bottom cover and clean pump
Sep 07, 2008 | GE WSXH208A Front Load Washer
Ge front load washer, 7 years old
speed control module faulty replace it .Close Ireland bye bye
Nov 22, 2007 | GE WSXH208A Front Load Washer
GE WCVH6260F Front Load Washer Logo
55 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
