Question about Frigidaire GLGT1142CS Top Load Stacked Washer / Dryer
Dryer my dryer will not start. i thought the breaker was tripped because the washer was not working either, but i have fixed breaker and washer now works, but not dryer. would the switch that starts the dryer need replacing?
I WOULD CHECK DOOR SWITCH FIRST
Posted on Jan 31, 2008
I have kenmore washer/dryer combo model 970-C98802-00. Been using for years until last week it starts tripping the breaker when using the dryer. It does not trip the breaker if no heat. It only trips the...
since it runs on air you have a grounded heater coil. Either the heater has sagged or broken and is touching the frame, here is a website that will assist you, Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 31, 2011 | Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Wont start , The circut breaker tripped, when i restarted it, the dryer worked but not the washer
Hello. The dryer and the washer are on seperate breakers. Check all of the breakers by turning one all the way on, then all the way off, then all the way on again. Do one at a time.
Oct 28, 2009 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Blows circuit breaker
sounds as if there is a short in the starting switch but there is a short somewhere in the controls good luck
Dave
Sep 15, 2009 | Amana ALE331RAW Gas Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Washer doesn't work, dryer does- HELP!
  • check your breaker, one side of the 220v circuit breaker may have tripped causing only one of the units to work.
  •  turn your breaker off then back on.
Jun 28, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire GLGT1142CS Top Load Stacked Washer / Dryer Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
