Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
What`s seems to be the porblem
Sony tv trinitron model kv-32s22.tv comes on an has picture then will go black but will still have auido .can cut power off but picture will not come back.can sit a day an cut back on an will have picture for a second or two
  • 1 more comment
  • fruitloop65 Jan 31, 2008
    yes the power ligth does flash.but you don`t see any lines in picture.an if it is the vertical i.c. what do i need to do to fix it or do i need to take it too someone.
  • Anonymous Jun 02, 2008
    Sony Trinitron 32" plugs in, audio is perfect, there is no picture. The Standby light blinks steadily on/off/on/off/on/off. It doesn't appear to be blinking an error code.
  • DON BLACKSTONE May 11, 2010
    WHEN THE PICTURE GOES OUT DOES THE POWER LIGHT FLASH AN ERROR CODE ? DO YOU SEE LINES IN THE PICTURE ? I COULD BE THE VERTICAL I.C. . IT IS VERRY COMMON ON THE SONY TV'S.
    DON..
  • 21 Answers
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Posted on Feb 01, 2008
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture flashes off and on kv-32S22
Your local TV repair guy should be able to go in and recharge the picture tube. Just had mine done for about $165 and it looks good as new (and this was on a KV-32s22 that we picked up at a yard sale). Well worth it.
Feb 04, 2009 | Sony KV-32S22 32" TV
Screen went black and never ressurected
It is repairable.Open the TV and check the fuse and then the flyback transformer for any loose soldering. check for obvious burnt transisters, resistors, capacitors etc. the flyback is the component that has a wire to the picture screen on the inside of the TV. Be careful. Capacitors and picture tubes retain high current. If you don't know what your doing take it for repair.
Dec 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony trinitron
the porblem is in the power supply section.check all of the parts within that section
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Have a 32 sony trinitron
Can you give me a model of the TV. It will be KV32?????
Nov 29, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-32S22 32" TV Problem
Intermittent dead with red standby light on, but won't switch back on, comes back on it's own, won't respond to remote or local controls
Low 5v standby supply due to diode D869 faulty, check by replacement
Nov 23, 2007 | Sony KV-32S22 32" TV
KV-34HS420-Sony Tv
well based on ur info, ur tv has a prolem in power supply section, particularly regulation circuit. the regulator of the circuit seems to be mulfunctioning thats why insufficient voltage is coming out from B+ which in turn goes to high voltage circuits thats why the produced picture is insufficient. if this is very technical to u, have it check with a qualified technician.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
