Question about Brother IntelliFAX 2800 Laser Fax
Document feed problem
I just got this machine. I get it all set up and try to copy but the document won't feed properly; plus the machine is making a clicking sound. any help?
  • 2 more comments
  • ma_pottsy Jan 31, 2008
    There is nothing in the manual about this problem -- at least I did not find it. I went through the routine maintenance yesterday and did not notice any paper bits around. It is like the document feeder won't pick up the page, then the copy is not right because the original doesn't feed correctly. Any other ideas?
  • ma_pottsy Feb 01, 2008
    I am at a loss here. When I try to copy a document the machine like clicks and doesn't take the document; when it does it is still noisy; most of the time the copy is only a partial. the actual print quality is good though. any help out there?
    This is the intellifax 2800, not supposed to need drivers; it is not connectred to a pc. Have checked for paper, none found. thanks
    Hey , the drum was supposedly replaced not long ago. I bought this unit used. Anyway, I am kinda lame with tech stuff; How exactly can the proof be found when I stop printing?
    Genius:
  • 1,067 Answers
Ya do u have all latest drivers install fom brother website unplug it all off for 2 min then all back in with new driver install
Posted on Feb 01, 2008
  • Anonymous Feb 01, 2008
    also u may wann cheak the feeder for thin pices paper that got stuck in ther pop top off cheak rollers thats feed paper in ok
    Genius:
  • 3,422 Answers
Here is the manual for it go through it carefully and u will find the solution to ur problem.
Click here to download.Once u enter this site type ur email id and then click start download.
And i am further looking for a sol. to ur problem.
Goodluck,
please don't forget to rate me as fixya..
Posted on Jan 31, 2008
  • 1 more comment
  • Priya darshan Jan 31, 2008
    You need to have adobe acrobat reader to view the manual in pdf format.
    Click here to download it.
    And one more thing is open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
    Also look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
    This is area where the original document feeds through.
  • Priya darshan Feb 01, 2008
    Needs fuser replaced from the sounds of it, but may be drum.
    Fuser above
    Drum below
    link to purchase
    You
    can prove if drum or fuser by stopping print at about half way and
    checking if fault is present when stopping paper before fuser but after
    drum.
6ya staff
SOURCE:
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Okifax 5680 - transmit resolution issue
You can change the Transmit Resolution but not the resolution or the quality of the faxes received.
If your machine makes goog copies and prints, the problem is on the sender's side.
This is an excerpt from the troubleshooting section of your machine manual:
The image received on your fax machine was very poor. Contact the person sending you the fax and ask them to change their Transmit Resolution and Type of Original settings. Ask the person to make a copy of the document on their fax machine to ensure that it is working properly. Then ask them to send the fax again. If you still have a problem, try making a copy of a document on your machine to make sure it is working properly
Aug 14, 2009 | OKIFAX 5680 Led Printer
Fax T 104, can recieve but not send. Can hear the fax signal fro
When you hear the fax signal press the start button on your machine. If this does not work attempt to just make a copy of a document without sending to test the document feeder - help the document by gently pushing the document into the machine when it should be feeding. If you can feel the machine trying to grab it but it doesn't have enough strentgh or it will feed with your help then the feed rollers are probably dirty and you may be able to open up the top cover and clean the rubber rollers with alcohol or degreaser. If the feed rollers do not even turn when trying to make a copy then you may have a motor, belt or clutch problem. If it copies well but will not send, then you will probably have a modem or fax lead problem. Try a new fax lead.
Jul 08, 2009 | Brother Office Equipment & Supplies
Canon 3200 - trying to do booklet printing, saddle stitch. The booklet should be 2 pages total (stitched together) but only one page comes out (with no stitch since it is one page) and a page of my...
Are you sure that the original documents fed through properly? If the document feeder double feeds then the machine will think that there is only one document, the first one. If the machine does not through up an error then this may well be the problem. Check with normal copying first. Also remember, you would need at least 5 or more documents to make a booklet as each page has 4 A4 pages reduced to A5.
Jun 24, 2009 | Canon imageRUNNER C3200 Copier
Continuous run when coping
The machine is trying to feed toner to the developer assy.Check if you have toner in the cartride and that the cartridge is propperly set.
Mar 29, 2009 | Canon NP 7130 Black and White Copier
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Faxphone is not copying or feeding
try opening the cover where the document feeds in, make sure there is not any objects obstructing the path. If not try taking a rag moist with rubbing alcohol and thoroughly clean the rubber rollers and the square rubber pad on the back side of that cover.
Jun 18, 2007 | Canon FAXPHONE L80 Laser
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
65 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
