Question about JVC AV-27F702 27" TV
Tv picture is black, sound is fine
I have a JVC I' Art AV-32f734. When you turn on the tv you can hear it,
but there is no picture at all. I pushed the menu button because I thought
the brightness was turned all the way down; but even the menu will not show.
  • 2 more comments
  • adirondkstud Jan 31, 2008
    4 years
  • kstrassel Feb 11, 2008
    I have the same problem with my JVC I Art. When the tv is turned on, there is a bright horizontal line in the middle of the screen with about three inches of picture above it and nothing else. There had been lines running through the picture for a couple of weeks now, but this just started happening last night. The sound is fine, however. Is this worth fixing, or is it time to upgrade to a flat screen HDTV?
  • lisosky Mar 22, 2009
    The sound works, but the screen is black. It's a flat screen JVC about 4 years old.
  • Greg Collins May 11, 2010
    how old is it?
  • 579 Answers
Sorry, no easy answer here. On an older set this would be espected and not worth repairing, but you should take this to a TV shop for troubleshooting. Most likely culprit is the flyback transformer and/or the horizontal deflection.
Hope Ya Fix It.
Posted on Jan 31, 2008
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 03, 2009 | JVC AV-32020 32" TV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
JVC TV
Call the service. There is nothing for you to do inside the TV!!!!!!!!!
Nov 13, 2007 | JVC AV-27230 27" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
JVC AV-27F702 27" TV Logo
173 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
