Question about Onkyo TX-V940 Receiver
Onkyo TX-V940 Has no volume at switch on, After pressing function buttons volume comes on. Left & Right channels cut out intermittently.Dave
  • Stic Jan 31, 2008
    Hi, Yes all connections and cables are connected and in good condition
  • Stic Feb 14, 2008
    Thanks Heaps for your help. It was the relays partly burnt.
    Stic
    Genius:
  • 3,422 Answers
the protection circuit has failed. I sometimes find that the contacts in the protection relays will be slightly burned and that will make the sound cut out randomly. Turning the volume control up higher than normal will make the open circuit of the burned relay contacts work again and so will the sound.
in most cases replacing the protection relays will fix the problem. You may want to first verifiy that the relays are defective by measuring the contact resistance when the problem shows up.
Goodluck,
Don't forget to rate me as fixya..
Posted on Jan 31, 2008
  • Priya darshan Jan 31, 2008
    Here is the user guide manual go through it carefully i hope u will find a sol.
    click here for the manual,once u go to that site then just enter ur email id and click start download
    And If u don;t find anything in the manual then you have to replace the protection relays..
    You need to have adobe acrobat reader to view the manual in pdf format.
    Click here to download it.
    Please don't forget to rate me as fixya..
    President:
  • 1,944 Answers
Did you check that all the connections are fine and that the cables are not damaged?
  • Damen Wong
    Damen Wong Feb 01, 2008
    If possible get someone certified to have a look inside your unit to see that there is no hardware malfunction inside (I suspect in your case it's a hardware malfunction).
  • Damen Wong
    Damen Wong Feb 15, 2008
    I am glad it worked out for you.
    Thank you for using FixYa!
Onkyo tx manuals
http://www.manualslib.com/manual/302311/Onkyo-Tx-Sv414.html#product-TX-V940
Jul 25, 2014 | Onkyo TX-V940 Receiver
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
TX-V940 only comes on with standby/receive light on nothing on display
I HAD ONE AND IT DID THE SAME THING ONE OF THE BUTTONS WAS STUCK SO CHECK ALL THE BUTTONS AND IT SHOULD COME BACK ON IF THE STAND BY LIGHT IS ON
Nov 20, 2009 | Onkyo TX-V940 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
335 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
