Question about Maytag MSD2454G Side by Side Refrigerator
Noise fan blades hitting something, can shake, may or may not stop, may go for a month not do it and the do it numerous times a day.
  • Maytag Master
  • 3,051 Answers
Pull the unit out and see if you can remove the cover for the fan and see if there is a loose screw or see if there has been damage to one of the blades try to straighten the blade if bent ok good luck !!!!!!
Posted on Aug 09, 2008
My fan oven is making a bad noise when turned on
Either blades are hitting something or bearings in fan are bad. Replace fan for latter.
Sep 04, 2017 | Ovens
How do I fix feezer fan noise
ok you must have a freezer full of stuff and its hitting the fan blade move the stuff away from the fan blade
Sep 08, 2014 | Refrigerators
Exhaust fan is hitting something while running
The fan blade shifted (moved) on the motor shaft. Take it apart (usually from the rear) and move the fan blade a 1/4 to 1/2 of an inch to clear the housing. Don't add oil to the shaft otherwise it will move again.
Jun 25, 2013 | GE Ovens
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Motor noise from Bosch freezer 'noFrost' unit area sounds like a fan blade striking something on each rotation. Stops when door opened; starts and continues for several minutes when door closed.
Hi, If you say it stops when the door is opened and starts again when you close it, it is the evaporator motor in the freezer its self. The blade/prop is hitting maybe a chunk of ice or may be a part of the casing some where. This motor is 120 volts and the blade is either aluminum or plastic. You can fix this on your own if you are a handy guy, you just need to get back to where the motor is and plug it in to see what it is hitting.The bearings may be going out causing the motor shaft not to be true and hitting. You will be able to see the motor turn and know if it is straight. I don't believe that's the problem, something has moved slightly causing the blade to hit it on start up.I have seen this happen many times.Once you get the cover off, it should be a quick fix for you. Keep me posted. If it turns out to be the bearings as you will see the shaft wabbling, take it out, make sure you unplug it, an get the name Bosch, model, and serial numbers and get one at a appliance parts house. Like I said, I don't think its the bearings or it would stop working or be real noise all the time. The blade is just hitting something small. Keep me posted,
Sincerely,
Shastalaker7
Mar 23, 2010 | Freezers
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
My ceiling fan wont stop shaking
sound like the fan is unbalanced , go to HOME DEPOT or any hardware store and purchase a pack of weights , these are small weights with self adhesive on them, to BALANCE IT start with one blade at the time , with the pack of weights it should include a square black horseshoe type to clip on the fan blade , this black clip is to let you know where to put a small weight, OK , so clip on at the middle of 1rst blade , start fan at high speed , if it shakes less , put on a small weight , do the same with the rest of fan blades , until it stop shaking , hope this helpful , AJ
May 18, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Strong noise notebook, CPU gets hot 75-80C
The fan may be faulty, it may have stopped or spinning slow.
Check the fan and clean dust/lint off the fan blades and heatsink fins. Spin the fan blades with your finger to see if it spins freely.
If necessary replace the fan.
May 04, 2009 | HP Pavilion dv8230us Notebook
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Maytag MSD2454G Side by Side Refrigerator Logo
37 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
