I have a 2003 Ferrari 360 spider, when i try to put the convertible top down it only retracts half way and sounds like the motor is binding any ideas would be helpful
The most common reason for this is low hydraulic fluid. The noise is probably the pump running while empty. When fluid id present it dampens that noise. Behind the rear seat is the combination motor/pump/reservoir. With the top in the DOWN position, fill the reservoir with ATF and cycle the system a few times as far as it will go. Repeat until the reservoir will take no more fluid. If that works, it is only a patch fix. You must now inspect the lines, motor and cylinders for leaks. The fluid does not evaporate. If it is low, you have a leak. Karl at topgunwon.com
