Question about Saeco Magic De Luxe Espresso Machine
Magic anstatt of coffee in my cup the coffee run in to the dregs drawer... or it just goes KLICK KLICK KLICK and seams to get no water...
  • 1 more comment
  • eodbrat Jan 31, 2008
    thanks Pierre..yes I got steam...just tried again to make a cup...the prebrew u can hear run in to the dreg drawer...then some comes out in to the cup the other half run in to the dreg drawer...just got this machine like 3 mos ago..
  • eodbrat Feb 01, 2008
    Pierre you are the bomb...think when i did clean the filter did not tightend them right or even backwards...hey what can i say...i'm a woman...
    so did what u said and just tried and it's working..
    thank you so much
    Sabine
  • eodbrat Feb 02, 2008
    thanks...I ride a harley...u been very helpful...
    Sabine
  • 2,039 Answers
When you put the machine do you have water or steam coming out of the valve if yes the brew unit might be block check it out clean it or unblock it cheers
Posted on Jan 31, 2008
  • pierre laplante Feb 01, 2008
    open the side door on top you gonna see a switch put something to push the switch on just like the door is close make a coffee and look were it leaking you probably see a leak on top off greg drawer there a tool that come with the machine when you whant to clean the filter that screw cost about $5.00 at saeco the screw hold the filter in place dont forget it plastic tight just enought if not you gonna strip the tread cheers
    i hope gonna read this 1st tanks for the rating 2nd that part of the filter is very weak try not to remove to often i sure it gonna stripe the tread clean it with soapy water rinse after when its dry apply grease that for those machine in the slot that goes up and down and for you been a women im a mechanic and i prefer dealing with women because they whant to understand what going on men they think they no it all men are a pain in the a?? if ever you have a car problem im here very happy to help you cheers pierre
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Water comes out with the coffee grounds in the dregs drawer
Hi
Inside the door on the right at top center is a lever that goes from - to +. Move the lever towards the + but not all the way.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Bought new machine yesterday.says ventilate which i did,then jumps to dregs drawer full,which is empty and clean what can i do now?
Are you still having the ventilate sign come on? If so, let hot water run out for 10-15 sec.
On the dregs drawer full message- carefully put back the dump box -making sure it slides in right. This happened to me the first time until I figured it out how to carefully put it back. If it is not in all the way, it will keep giving you that message.
Jun 16, 2008 | Saeco Magic De Luxe Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Magic
Klicking is the gears. Klick Klick Klick is the machine skipping gear spots and trying to recover.
Needs new gears.
Could also be the main boards going bad since the board controls the brew drive and the gear system.
Its one of the two. If it is the board, saeco cannot fix it and they do not have replacements. They stopped carrying them about 6 months ago.
Mar 23, 2008 | Saeco Magic De Luxe Espresso Machine
Tray and Dregs light flash when machine turns on
You can't make the light go out because the dreg drawer, brewing unit and drip tray, all activate micro switches when they are inserted. One or more of the micro switches have gone open circuit, or they may just be dirty or clogged with coffee granules. You can only fix this problem by opening the machine up.
The light goes out when contact is made with the micro switch. No contact made, no light goes out.
Dec 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
89 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
