Question about Amana ABD2233DES Bottom Freezer Refrigerator
Ice machine makes noise constantly
The ice machine is making noise all the time (even when the bar is raised). Only when the refrigerator or freezer door are open does the noise stop. Any ideas?
    President:
  • Amana Master
  • 2,651 Answers
Niosy ice maker, replace it
Posted on Feb 24, 2008
Ice bin full does not shut down.
It really helps to know the model and make of the refrigerator. The full bin on some models have a bar that gets raised up and if the bin full, the arm gets raised high enough to open the circuit for ice production. When ice is used the bar lowers and a Microsoft in the controls shut starting the ice production again. If bar is missing it will keep making ice until you raise the bar to the off position.
If you have one of the new type ice machines, some of them use infrared sensors and thermometers and the like to sense ice production.
If you have a fairly new refrigerator, it may be still under warranty and for small fee a factory trained representative can analyse cause and replace broken parts under warranty. Warranty information will be in the information package that comes with the machine.
Hope this helps!
Apr 19, 2016 | Refrigerators
Ice maker makes noise like it is working but turned off
If you want to have a working ice maker it will need to be replaced. You can buy the whole unit part # 1129316 for almost the same price as any of the individual parts. Behind the unit on the back wall is a plug with several wires unplug this plug to disable the icemaker.
If I can be of further assistance please let me know.
Apr 15, 2010 | Kenmore 53642 / 53644 Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Our GTS22KBPWW refrigerator is making a very
How loud?, could be the icemaker. Does it make ice ok. try raising the ice tray bar to see if the noise goes away.
Jul 15, 2009 | Refrigerators
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker bar sticking at bottom now a loud grinding noise
you can replace the whole ice make or remove the head and replace the cut off cam inside the ice make head..
hope it helps
Jun 20, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
Icemaker noise and malfunction
on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
Feb 19, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Amana ABD2233DES Bottom Freezer Refrigerator Logo
464 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
