Question about Toshiba MV19N2 19 in. TV/VCR Combo
Mv19n2 tv vcr
I moved two years ago and lost my control and manual. recently I got cable and connot program it in because there are no out side controls. I have tried buying remotes but cannot get them to work. Please help
    Problem Solver:
  • 8 Answers
Getting replacments is one way, another way is try to get a universal remote- costs around $20 for a good one and they will work for all your home video & tv STUFF! This should work, but make sure you get a good brand remote, cause otherwise it wont work with the TV or any of your other stuff properly! Hope this helps...
Brentic
Posted on Jan 31, 2008
    Sergeant:
  • 395 Answers
AD301651 is the part number for the remote and you can get them at www.vancebaldwin.com
the manual you can download here http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/mv13n2_w_mv19n2_w_ownman.pdf
6ya staff
SOURCE:
I dnt have a remote for the tv also their is no menu on the front panel wat can i do
You should have cntrl buttons on your tv on the side, top or bottom of tv with INPUT select. If its an older tv it might have a cable / antenna switch. Might have to look around.
Hope this helps
Feb 11, 2015 | Toshiba MV19N2 19 in. TV/VCR Combo
I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
Sep 20, 2011 | RCA Universal Remote Control
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Dec 13, 2010 | Televison & Video
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Manual for Quasar VHQ-940
I need to find out how to record on theVHQ940. I bought a used VHQ940 without a manual or remote. My son used a universal remote to turn it on to my Magnavox TV, but don't know how to program it to record. I need a manual.
Mar 24, 2008 | Quasar VHQ940 VHS VCR
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
Menu
Yes most sets you can go into menu and reprogram in cable or ant. Does the set has a menu button? If not, does the remote have one?
Sep 09, 2007 | Toshiba MV19N2 19 in. TV/VCR Combo
Toshiba MV19N2 19 in. TV/VCR Combo Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
