Question about Sharp AL 1631 Copier
Documents not feeding
Documents aren't feeding at all from the ADF. Copier is already several years old.
  • alex oakley Feb 06, 2008
    It is damaged. Now what?
    Problem Solver:
  • 14 Answers
Does it sound like it is trying to feed at all or does it feed about half way and stop. You may be looking at a feed rollers problem, worn or dirty.
Posted on Feb 10, 2008
    Genius:
  • 1,003 Answers
There is usually a switch sensor lever in the area where paper is loaded into the document feeder area(near the document feed roller check to see if its not stuck or damaged
Posted on Jan 31, 2008
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Panasonic DP3030 Workio copier - won't feed document on top ADF
Hi p Hinkle,
Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
Still having Problem Then follow Us For Panasonic Printer Support
Feb 07, 2014 | Panasonic Workio DP-3030 Printer
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
I am not able to feed several documents into my Cannon MF6500 printer to be scanned. I can only scan one document at a time. How do I correct this so I can feed documents in to be scanned
Do you have problem with multiple copies or just wit puling scans?
Try to say that the original is feed from adf, clean rollers if you have trouble with copie too.
May 18, 2010 | Office Equipment & Supplies
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Re:Minolta copier EP 2151 I am trying to print a stack of documents using SDH mode (semi-automatic document handling). The SDH mode green light comes on and blinks, but the light on the "go' (print) button...
If the green light on the adf is blinking that means that there is a paper jam in the adf. I sure you know that the copier you are using is at least 10 - 15 years old. Has the adf worked recently? Are one of the adf hings broken? If so, line the adf straight on the top of the copy board glass. There is a magnet that needs to be closed to make the adf work. Try to see if there is any small piece of paper in the papeer path of the adf and use a can of air to blow out the sensors and get back to us.
Jan 14, 2009 | Canon imageRUNNER C3220 Color Copier
Users Manual
the ADF is the automatic document feeder the part on top of the machine that you insert the paper to Automatically feed the paper in one at a time, there may already be a document on the glass lift the top and put it back down it should clear
Jul 31, 2008 | Canon PC-1060 Black and White Copier
ADF for MP530 does not work
Welp, I pulled out my screwdriver and fiddled around just a bit and got documents to feed again (yay!). I do not believe this is a permanent fix, though, but it was enough to get my document scanned in without me having to feed each sheet manually.
Step 1: Open the document feeder cover. Easy to do, you just stick your hand under it and lift up. It has a little pressure because of the latch but it is designed to give way when you lift hard enough. Once it's open, pull out the little black plastic piece that keeps the cover from swinging all the way open.
Step 2: Unscrew the ADF motor/gear assembly cover. There's a single screw holding it in. Once you unscrew it, you'll need to pull up on the left side of the cover until it pops upward, then you need to push the cover towards the left until it is freed up from the rest of the cover. This one was a little tricky. Several times I thought I might break it (before I realized that I needed to push the cover towards the left) so try not to apply unreasonable force while you're doing this.
Step 3: Close the document feeder cover, put your documents in the feeder and start your scan. Use your fingers to fiddle with the gears while the ADF motor is running and trying to feed documents. I'm not sure if I flicked the little gear upward or downward to get the documents to feed, but one of those ways got the documents to start feeding. Once it started feeding the first page, it seemed to work well for the rest of the pages without me having to fiddle with it anymore.
I am guessing that there is some level that controls the location of the middle gear that needs to be oiled, but I didn't go any further to try and make that happen. Hence this is probably just a temporary fix for now.
Putting it back together is pretty straightforward. Just do the reverse of what you did to get it open.
Hope this helps someone!
Jan 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Sharp AL 1631 Copier Logo
180 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
