Question about Kitchen Ranges
220v loss on one leg...
Kitchen range suddenly went luke warm. I found one leg has dropped to 21v. At the breaker 220v. Breader seems to be working fine. Outlet seems to be working fine. All wires and connections are in good order. What do I do next or where might I look to find the problem. sumation: Power at box 220v. Power at cable going into socket: 21v on one leg, 240v on other leg...
Help!!!
  • ElectroHead Jan 31, 2008
    Saskcat:
    Thanks for the info.
    To answer your question about the bus measurement at the box, I first cut the breaker off. The red and black leg terminals are in direct access, so with the breaker off I took an ac reading. Now with the breaker on I took the same reading with the probes and got 220v which told me the breaker was working. I realized that something had to be wrong between the box and the outlet. So, under the house I went and behold, i found where the previous owners had nut capped the 220v lines together to extend them, and it was on the ground. upon working the wire nuts I found the leg I was having the low reading on was loose.
    Again making sure the circuit was off, I trimmed and reconnected all connections and taped them to the cable. Then I hung the cable up off the rafters to get it off the ground. Went to the box, turned on the circuit and five minutes later I was making tea.
    The range works hotter and faster than before. I think that with the heating and cooling that happens whenever the stove was used disassembled the connection over time. Also, it didn't help that anytime I had work done under the house, you would invariably hit the cable. With my fix the thermal loosening should no longer be a problem...
    Many thanks again for your response...
    ElectroHead--
    Problem Solver:
  • 30 Answers
Ok. lets make some assumtions. You must be of some electrical background to take a measurement such as 240v 21v. I will also assume you are measuring to ground (the half U).
I will also assume you are measuring at the wall recepticle(plug on wall / or even in the back of the range itself if no plugin)
1) four colors there. red, black, white, bare. or u-ground, middle-white, either side red/black.
2) measure from ground (U) to either side. should show 110v each.
3) measure from middle blade to either side and it should show 110v each
4) if either of those reads are not that, then you can look for a nail or a sharp edge that has poked through or cut through the range cable between the panel box and the range.
5) when you find the problem call an electrician in to fix it. it shouldn't cost much as you have done all the leg work.
6) one more thing- make sure the power at the panel box is 220v. I'm not sure how you did that this far, but you must use extreem caution as not to get zaped.
CAUTION must be used with cheap meters, as they can fail also.
7) if the break is close to one end, the electrcian will probebley add on some new cable and you will be ok.
call back with more info if you want :)
Posted on Jan 31, 2008
Oven and stove does not get hot. control panel seems to be working but nothing gets hot.
I can only guess but I think you are missing voltage on one leg of a 220V circuit. If you have a fuse panel 1 fuse is blown. Circuit breakers are made so that if one side trips it will automatically trip the other side but I have seen them fail. There is also the possability of a bad connection.
Oct 16, 2014 | Kitchen Ranges
Clock and wiring seem to be working and temperature but oven won't get hot nor burners
CHECK YOUR HOUSE BREAKERS TURN THEM OFF THEN BACK ON.YOU NEED 220V FOR THE ELEMENTS TO GET HOT.110V TO RUN THE LIGHTS AND CLOCK. GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | Frigidaire PLEF398AC Electric Kitchen...
I have a model MER5755QAS. Oven/broiler not working right.
Sounds like you may be getting only 110v to unit. After unplugging, Check for any burnt wires around terminal block or around elements. Also first check if breaker may have half way tripped. Cut breaker for stove all the way off and then back on. The bake element may have partially tripped the 220v breaker thus only sending 110v to unit.
Oct 31, 2017 | Maytag MER5775Q Electric Kitchen Range
Counter top or oven will not heat up.
Go back to you breaker box. Re-set the breakers on each side of the one you re-set before. Now try it. Thr range works on 220v. This consist of two breaker leavers. One for each leg of the 220v. If you only re-set one leg, only half the things work.
Please rate this solution
Aug 26, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Mar 11, 2009 | Electrolux 30" Self-Cleaning Freestanding...
Plef398ccc burners not turning on and rechecked wiring
my assistance has already been rejected, so i don't know if you will get this post. before buying any more parts, check to make sure you are getting a full 220v at the outlet and test each leg (110v) against the neutral and ground wires to make sure they are good too. when you get a short, like the dead mouse scenario, the breaker might trip on one side of the dual breaker, giving you a machine that seems to have power but does not function properly.
Jul 13, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Oven elements don't work,Bake broil or clean. Display works.
Always check your breakers first (220v breaker has 2 legs, be sure both sides of the breaker are in the solid on position) and plug. The next step will be to verify voltage to the element, if it has 220v then the element will have to be replaced if it doesn't then you'll have to find the contactswitch for the element. High amperage components such as oven elements tend to be tough on contact surfaces in switches , carbon deposits build up and the contact fails, You must find the failure in the circuit and replace the faulty component.
Mar 03, 2008 | Kitchen Ranges
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Kitchen Ranges Logo
250 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
