Question about Brother MFC-665CW All-In-One InkJet Printer
No Cartridge I only use OEM cartridges, I keep putting in a new black on and it keeps saying "NO CARTRIDGE - BLACK" not under warranty, is there someway to reset machine or any suggestions, they are 27.00 each and I have now bought 5 of them, help please? I keep doing exactly as it says, no problems with other colors
  • Deborah Offenberger Jan 31, 2008
    yes has ink, all the 5 have, well I had needlenose plyiers and tried to pull the sensor, couldn't , so I just reinserted cartridge and it started working, thanks for your help
  • Mergatroid May 11, 2010
    Remove the cartridge and look into the back of the cartridge slot. You should see a black U shaped sensor.
    If there is spilled ink on it, the pcb will have to be removed and
    cleaned. Ink is conductive and can cause false readings from the sensor.
    If it is already clean, unplug the machine and remove the new black
    cartridge. Plug the unit back in, and wait until the "Bootup" operation
    stops and there are no more noises.
    Install the black cartridge and close the cartridge cover.
    If that doesn't work, there are only 2 remaining possible causes. The
    sensor is bad, in which case the board would have to be replaced, or
    the main board has gone bad. The latter is pretty unlikely.
    You should look into ordering a sensor pcb from a local Brother service
    centre if the cleaning doesn't work. They're not expensive.
    One last thing, make sure there is ink in the cartridge you are
    installing. At the rear of the cartridge, there is a window for the
    sensor to look into. You should be able to see ink in it. If you can't,
    buy your cartridges somewhere else.
  • 286 Answers
Putting paper or black tape over the sensor is not a very good idea. If the ink runs out 100% the machine cannot detect it. If you get air in the ink tubes, and the air reaches the print head, best case senerio is you'll have to do several cleanings with a new cartridge to get that colour working again. Worst case senerio, the air reaches the head, the owner stops using the machine for several weeks or a month, several cleanings are performed but the head had permenantly clogged nozzles, Brother leaves some small amount of ink in empty cartridges for a good reason.
This IS a good thing to do if you want to permenantly stop using colour though.
Posted on Feb 14, 2008
  • 4 Answers
I am sure this is the same problem as the 440cn. each cartridge has an optical window on it where the sensor measures the ink level. what u do is put a folded piece of paper over this window and reinsert the cartridge. this makes the sensor think that cartridge is full and should reset the ink meter. the printer should work fine.
Posted on Jan 31, 2008
6ya staff
SOURCE:
THINKS IT NEEDS An ink CARTRIDGE
probably needs to be an OEM dell cartridge . they have put chips in them now so we consumers have to spend more for them
Oct 10, 2017 | Dell 926 All-In-One InkJet Printer
I replaced the black in cartridge on a Canon MP620 with a non-OEM cartridge. Everything seems to work fine, bu I keep getting a message that the cartridge is empty. I moved the chip from the original...
When you moved the original chip to the new cartridge, the chip is saying the cartridge is empty. Try removing the chip and the printer should know the cartridge is not empty, but might give you a message that it is not a genuine Canon cartridge.
Fred
May 09, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
I have a lexmark X4270 fax machine, and I have just got a new black ink cartridge. The old one was a lexmark 71 the man at Quill said to get a lexmark 75 hi-yield. so I did my machine keeps saying black...
Did Quill sell you a "OEM" (Original Manufacturer's Equipment) or a cartridge a third party cartridge?
If it is a third party ink or cartridge, then that's your problem. Lexmark does not condone the use of third party ink or cartridges. This is considered to be product tampering by Lexmark and they will void the printer warranty if damage results from the use of these type cartridges.
I do apologize for the bad news, but I do ask that you do not shoot the messenger. :-)
Jul 03, 2009 | Lexmark X4270 Printer
Printer keeps saying "INSTALL BLACK CARTRIDGE".
If you are using Windows.
Go into "Start", "Printers and Faxes".
Right click on the printer icon.
Click properties.
Look for reset cartridge.
Or something similar.
That should fix the problem.
May 29, 2009 | HP LASERJET P1006 Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Black replacement cartridge
This is an easy one, you do the black the same as each color cartridge. All four cartridges sit on a carousel that rotates.
Just keep pressing the button that's directly underneath the ready light until it says "rotating to black". After the machine stops rotating, open up the cover and put the black cartridge in.
Apr 03, 2008 | HP LaserJet 2840 Printer
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Brother MFC-665CW All-In-One InkJet Printer Logo
259 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
