My hdtv started smoking out of the top just behind the screen, what happened to it?
  • watkosco Jan 31, 2008
    It's a samsung hps 4253 and we acquired the television in the year of 2007
  • Greg Collins May 11, 2010
    Need to give the age, make and model please.
    Did you know that smoke is what makes electronics work?
    When you let it out of a part - it quits working!
  • 579 Answers
These are not the most reliable sets to say the least. The power supply portion of the main module has failed and it will be expensive. Fortunantly, this happened while under warranty, yes?
Good luck with Samsung customer service.
Posted on Jan 31, 2008
The TV started smoking. Thought it might be dust. doesn't appear to be.
Your tv is burning part of it's electronics. Turn it off and unplug it. Either take it to a repair ship or replace it.
Mar 27, 2015 | Philips 47PFL3603D/F7 LCD HDTV, 47...
My Initial hdtv-322 randomly turned off and smoke was emitted from the rear panel. i opened it up and noticed that the burning smell and smoke came from the pcb, "there was liquid evidence on the rear...
It could be the board. Check the capacitors on the board they are small cylindrical shaped parts. Look for any bulged tops on the capacitors which will indicate bad capacitors. Hope this helps.
Jan 09, 2014 | Initial HDTV-322 32 in. LCD Television
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen is blank and orange light stays on
The power supply board failed. Most cause is the electrolitic capacitors. They look like little soda pop cans. These should all have "Flat" tops if you see any with buldging tops? That is the problem . They are cheap and easy to replace. Just remember capacitors and components in general can hold a charge even after being unplugged for months. They can kill you. make sure you use caution. Discharge those caps. The bad caps are usually visable bad. I would replace them. These caps have a negative and a positive. If you put these in wrong? They will either fizz out and smoke or a loud pop and smoke will happen.
Thanks
Give me a good feedback on here please.
Jan 07, 2011 | Mitsubishi WD73727 73" HDTV
My Polaroid flat screen tv started smoking and the picture went off, but there was still sound. What happened and can it be fixed? This tv is only 2 years old.
It can be repaired, however, the cost is probably going to be in the area of $200.00 or so. Unfortunately these were not reliable sets. I have repaired way to many of them to recommend repairing it.
Nov 10, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Polaroid tv 32" flat screen tv and I heard a noise like hissing! It got louder and then my tv went out and smoke came from the top of it! So, can it be fixed and how much would it cost to...
99% chance the problem is in the inverter board that provides the AC needed for the flourescent lamps behind the LCD monitor.
There's a small chance it is the power board.
Oct 25, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Top of screen had 2 6'' lines across top of the screen,then it went all distorted and shut itself off. the unti is a 50'' lg model 50pg25 and is only 9mths old what caused this and is it upgradeable to the...
You can't upgrade a panel tv, plasma or LCD.You may have had a plasma panel failure,I sell LG tv's and for the panel to go bad is rare but I have had it happen approx.6 times in the past 5 years.I highly recommend contacting LG"s customer service they will stand behind the panel and get you going again.Good luck!
Nov 22, 2009 | LG 50PX5D 50 in. Plasma HDTV
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Liquid behind the screen
put a hair drier on low at the source of the problem, that should fix it.
Feb 10, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
