Question about GE JVM1340AW/BW/WW Microwave Oven
Not working model # jvm1339bw 002
We had a power outage overnight.the microwave, did not reset. I have power at the outlet. checked the fuse inside the control panel of the microwave,its ok.. could there be a reset button? This model was made Aug-1996.
  • Anonymous Mar 29, 2014
    is there a reset button on the microwave
  • 579 Answers
Check the main internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Posted on Jan 31, 2008
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
Hotpoint RVM 225 BL 002 power reset. Internal breaker?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I would suspect the fuse or magnetron thermostat.
May 15, 2010 | GE Microwave Ovens
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave on the blink after power outage in the neighborhood
There may be a fuse either inside the bottom cover or the back cover.
May 30, 2008 | Hotpoint Microwave Ovens
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
Microwave's timer counts down but doesn't turn on to warm food
The only motors would be the Magnetron fan cooler and turntable. Is there no heat at all?
Oct 07, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1340AW/BW/WW Microwave Oven Logo
323 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
