Question about Sanyo Xacti C1 Camcorder
Sound problems Hi I have a axcti mini cam C1. I am having problems hearing the sound while playing back the clip on the cam. I dont have any problems hearing the sound while playing back on my computer. could it be a "problem" in settings or is it a speaker malfunktion. My email: Thanks/regards Filip (Denmark)
I do not have no sound when I play a video back you can not hear. This is on my Nikon coolpix P520 camera
did you test your cam with previously recorded memory stick ?
if it gives sound, it means the speaker and audio sections are working well, if newly recorded scene not gives sound means, there may be problem with the microphone, change it.
Oct 22, 2015 | Nikon Cameras
I ned too instal may camera starcam clip MSI i ned cd fore instal it on vista
For Installing the driver of MSI camera starcam click hear and download the driver, after download the driver, click the setup file and install the driver, when installing finish reboot your computer, enjoy to using you CAM.
Jul 10, 2011 | MSI StarCam Mini Webcam
I dont know how to run my video clips continueously without stopping to press play again for the next video clip. I have a Jazz Elite HDV 178.
Often you won't have that option. What you will want to do is to use video editing software on your computer to string together the ones you want to play continuously and then save that. I believe that with the HDV178 software you can reload an edited video to your cam so that you can play it back on the cam to show friends without having to carry a DVD or computer with you.
Hope that helps.
Sep 22, 2008 | Cameras
Audio device problem
hi.. sir
please follow the step's
1. start
2. control panel
3. sound and audio devices
4. voice
5 test hardware
6. follow the step next ..
itwork's is ur audio device is correct.
thank u
sir don't forget to rate it..
Sep 04, 2008 | IBM ThinkPad R52 Notebook
CD does not play
This sounds to me like the loading mechanism is having problems. It may be as simple as the grease gumming up a bit, or the motor having a dead spot. Without seeing the machine itself, it is hard for me to say. I'd rebuild the loading mechanism and regrease it. Figure on the local labor rate for this repair as no parts should be required unless the motor has failed.
May 27, 2008 | Denon D-C1 Shelf System
No sound on movie playback
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
Good Luck.
Apr 09, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Audio volume
Unfortunately, connecting an external mic is not an option that was engineered into this model camcorder. Likewise the speaker and small amplifier for audio playback is simply what it is. You should be able to adequately hear normally recorded levels. If not, maybe there is a problem with the internal condensor mics or the playback speaker. If you are unable to obtain a resonable level using A/V cables to a TV, then something could be wrong. I have not seen problems with this model regarding sound, but anything can happen. Good luck, ms
Aug 30, 2007 | JVC Cybercam GR-DVL520A Mini DV Digital...
Won't play DVCAM, will play Mini DV
it is probably matter of dirty guide so the timecode stop reading try a wet head cleaning tape to play it there regards please don't forget to rate ,thx
Feb 20, 2007 | Sony DSR-45P DV / Mini DV VCR
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Cannot play back recordings
I have the same model and I also had that problem. It turned out to be the motor. Do you hear a faint humming sound? If this is similar, you will have to take it to a designated JVC repair shop.
Sep 24, 2006 | JVC GR-D270US Mini DV Digital Camcorder
Sanyo Xacti C1 Camcorder Logo
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
