Question about Soltek SL-86SPE2 Motherboard
Drive sata good night i'm in Portugal, and i need a sata drive to my board , where can i find it? tks a.mateus
You should contact PC-REP, they got the answer...
PM
Posted on Feb 01, 2008
    President:
  • 2,351 Answers
How do i get my sata ports on my motherboard to work?
Hi there. I think your board is an early SATA board as it has IDE connectors too. I am not able to access the website you have listed but have had a fair bit of experience with SATA drives on such boards. It might well be that there is an option in your bios to switch between native SATA support and IDEmode. If you can find such a facility in bios then try changing it. You should try the drive on another machine to ensure that it is not defective, if the drive is a new one then try it on a very recent machine.
The issue might that the hard drive is not compatible with your board, some SATA3 drives will not work on older boards. The is true of some SATA2drives. It might just be an incompatibility issue.
Good Luck
Feb 10, 2015 | Computers & Internet
I need to hook up a CD drive to my computer. I have a P5GC MX/133 mother board, two 256 gig hard drives and 3 1/2 disk drive. I would preferr not to diconnect any of the ubove
Hi kbrotzel,
You didn't indicate if your Hard drive is a SATA or PATA. So, I'm going to assume the problem your having is that the drive is a PATA, and your trying to install another PATA drive, when the board only comes with one IDE slot for PATA style drives. What you need to do is to exchange the CD ROM drive for a SATA drive, so you can put it in one fo the SATA ports. If they are both SATA, then just plug it into one of the SATA ports.
Good Luck
Mark
Nov 22, 2009 | ASUS Computers & Internet
Replace dvd drive need sata adapter
Replace DVD drive doesnot need Sata adapter, check your dvd and your board if they are compitatble, if your dvd is sata and your board use sata too, you just need sata cable + the dc cable comes from power supply.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 01, 2009 | Sony VAIO PCV-RZ40C1B PC Desktop
Hard Drive Recovery
the best recovery program takes a long time, if any of the program takes shorter time then there is a chance of not getting all the data back. u can try get a ups so that if there is a power failure it will help u.
Dec 28, 2008 | Acer Aspire™ T180 PC Desktop
How to I connect my SATA DVD drive to the motherboard?
Hi Vicrod,
I'll need a better model number than "845" to give you a definitive answer, as ASUS doesn't name their boards that way. I suspect that the board supports the Intel 845 chipset and that's where the 845 comes into play. If you don't have the owner's manual, you'll need to look at the board real close; you'll find the model number stamped on the board. The good news is that if the board was built in the last 3 years or so it should have built-in SATA connectors (at least 2, probably 4 or more). If your DVD doesn't have the IDE cable and instead has a much smaller cable, it is in all likelihood SATA. In the worst case, even if your MB doesn't support SATA, you can buy a SATA PCI card to hook the drive up to for under $30. Finally, you can go to www.asus.com when you get the full model number. From there you can download an owner's manual that will have the SATA ports labeled.
I hope this helps you. If you think it appropriate, a fix-ya rating would be much appreciated.
Bob
Oct 29, 2008 | Computers & Internet
Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Oct 28, 2008 | MSI K8MM-V Motherboard
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Soltek SL-86SPE2 Motherboard Logo
161 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
