Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
My Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times. Occasionally the tv comes on but wont cycle on/off again. I've tried leaving it unplugged for over 24 hours, no difference. Any ideas? Have a FD Trinitron WEGA KV-32fs120 TV will turn on occasionally and works fine when it is on. If it gets turned off it takes 2 hrs to get it to come back on. The LED flashes 9 times please help TV was purchased in JAN 2006 Problem started in JAN 2008.
  • Anonymous Mar 20, 2014
    TV will not turn on when you push power button...red LED light flashes 7 times...have tried using a hairdryer on air vents in back of TV but still did not work
  • 1,113 Answers
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
  • Soulvisitor
    Soulvisitor Jan 31, 2008
    Sorry can't make it bigger but it seems that the other experts here might have more idea than I
    Cheers S;)
  • 2,336 Answers
9 blinks means that D 6116 and D 6301 on the "G" board may need to be replace, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Let me know if you need more assistant.
  • Jaime Hernandez Jan 31, 2008
    You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
  • Sony Master
  • 8,617 Answers
No zero cross pulses on Pin 45 of IC1001 on A board. Check the collector of Q691 on GK board for 7.5 V standby .It will go to 0 V on start up. If 7.5 volts on the collector Q691 is faulty if no volktage on Q691 need to trouble shoot further in vircuit to Q691.
Let me know if you need anything further.
Posted on Jan 30, 2008
    Genius:
  • 3,422 Answers
Here is the user guide,go through it carefully and you will find the solution to your problem.
Click here
And im further looking to fix ur problem
Goodluck,
Don't forget to rate me as fixya..
  • Priya darshan Jan 30, 2008
    Unplug the power cord and let is stay OFF for about 2 or 3 hours. Then
    power it up again and see what happens. This is what we call hard
    reset. It works to bring the set back to life in about 25% of
    occasions.
    If it does not help after the hard reset above then it will need to be
    looked at by a tech who knows how to navigate around a protection
    failure. The reason it won't come back on is because the protection
    circuit (and electronic, intelligent fuse) has detected a severe
    shorted condition somewhere within the set. It is usually the main
    power supply, the high voltage section or one of the deflection
    amplifiers. But, can be from other sections within the tv. That is
    why you must have some diagnosis completed to find the problem.
    Another cause, less frequent on this class of tv, is from bad or cold colder joints
    Champion:
  • 207 Answers
Sony KV blinking red light
Probably defective power supply. Fixya is unable to recommend replacement parts sources.
Jan 24, 2018 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Wega trinitron TV wont turn on..Keeps shutting off and standby flashes 7 times
Thank you for your question.
Fortunately this is a common symptom and there is a fix for it.
There are two power supply IC's and a capacitor that need to be change. In particular IC6501, IC8002, part number, Mcz3001db, and C6556, 33uF @ 160V.
Jul 15, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv wont turn on, red timer/delay light flashes starts to come on then shuts off again
hi,
watch how many times ur standby indicator flashes. flashing of led is its self diagnosing system. if u tell me how many times its flashes, then i can tell u where is the problem
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony - no power
Well 5 times blinking indicates EEPROM ic getting malfunction. Change this ic tv is working well and good. Note that this ic comes only in blank you have to program it as your tv model.
Aug 04, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron tv does not turn on
most of that problem is due to defective vertical ic,and your protect system detect that there is a part/s defective.
Nov 01, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
560 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
