Question about BenQ FP731 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
BenQ FP731 Flat Screen Can it be repaired. Power went off and it was left on. Power came back on while montor was still in the on position. Monitor was then tuned off. When computer was turned on monitor was also tuned on but remained Black.It did not come on. The green light came on but no picture etc. Is there a fuse or restart for this monitor. What is the life of this type of monitor, this one is only 3 years old. Thanks . Ron.
  • booboo18 Jan 31, 2008
    I have the same problem with my screen going black. I was able to see an image ever so faintly when I looked at it from above the screen. I tried turning it off, unpluging it from the wall and computer and putting it back on with the same results. Is there a fix for this or a fuse that is going? My screen is only about 4 years old.
  • Anonymous Mar 07, 2008
    Same thing happened to me. Computer was set to turn monitor off in 20 min. The green light is on but it will not wake up...... I tried it with another computer but no luckl
    Champion:
  • 220 Answers
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Posted on Feb 16, 2008
Flashing
This is a very common symptom of a failure of the filter capacitors in the power supply board. The monitor is repairable, you just need to replace the 7 capacitors on the power supply board. Here is information on the board and the capacitors needed to repair it.
http://www.ccl-la.com/catalog/product_info.php?products_id=331
May 08, 2013 | BenQ E2200HD 21 inch LCD Monitor
I have a 50 inch panasonic 720 plasma tv and while watching it last night a large black box with white writing came on in the top right corner of the screen with mute in it and the sound went off. I...
Unplug the TV. Replug in the TV. If it's still there, you probably have a bad panel. Try changing inputs. These panels are non-repairable.
Jun 16, 2011 | Televison & Video
I have a philips flat screen (19 inch)...It will not turn on at all...no blinking light...no noise...not a thing... I've tried different outlets...unplugging power source and replugging. This tv was...
You have a power issue I would try to replace the power board.I repaired a phillips magnavox same problems.I purchase the board for about 75$ and got it back to customer.Sometimes you can repair the board and sometimes you cant.
Sep 29, 2010 | Philips Televison & Video
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Blown power supply
If it's possible, install a small computer style fan and direct the air stream over the power supply. You should then get another 10 years out of it. Unit needs ventilation and cooling air. Hopefully, it isn't installed in tight quarters.
Jul 18, 2009 | BenQ DV3750 Television
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank...
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Jul 15, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Apr 15, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
332 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
