Question about Canon LaserCLASS Fax 710 Printer
How to Add Speed Dial Numbers -- Can't find menu
Help!! Does anyone know how to add speed dial numbers into the Canon LaserCLASS Fax 710? We bought a refurbished machine and there was no manual with it.
Thanks!
Rena
San Diego
  • Anonymous Mar 15, 2014
    How to enter number for speed dial
The easiest way is to use the intranet interface. Enter the IP address of the fax machine into your web browser on your computer (on the same network) and you will get the interface. Select the administrator role (hopefully the password will still be blank), and then go to the address section. You can enter speed dial numbers there.
Posted on Aug 09, 2008
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
I need to set up one touch dial fax numbers
This should be what you're looking for:
Storing Speed-Dial numbers
1 Press Menu/Set, 2, 3, 2.
2 Using the dial pad, enter a three-digit
Speed-Dial location number.
Press Menu/Set.
3 Enter the number (up to 20 digits).
Press Menu/Set.
4 Enter the name up to 15 characters (or
leave it blank).
Press Menu/Set.
5 Press Stop/Exit
Apr 23, 2009 | Brother IntelliFAX 2800 Laser Fax
How do I do group faxing from my Canon L80 fax ?
Click here and download the user guide. The process is on page 6-13. You will most likely have to set up the numbers of the group in a "One touch speed dial" or "coded speed dial" before you add them to the group. Remember to leave the "one touch key" that you want to use for the group dial blank. Hope this helps....
let me know if you need anymore help.
Nov 13, 2008 | Canon FAXPHONE L80 Laser
Please help!!!
Select from the menus and go to that speed dial you want to delete, re write as desired and save... it should not be a problem..
Jun 27, 2008 | Canon LaserClass 2060P Plain Paper Fax
710 Fax - how do I set up Group Dial?
Reprogram the machine. Have the machine serviced, and check the battery that holds information when power is lost
Jun 09, 2008 | Canon LaserCLASS Fax 710 Printer
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Selecting speed dial number
Select the numbers from the directory, using the directory button.
Jan 23, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
How do I reprogram the numbers on speed dial ? and or add them or delete them?
Canon left me on hold for 30 minutes then told me this wasn't their problem and I should call my dealer for service.  I'll try that now.  Nope - they didn't know either.
Eureka!  Lift the panel that covers the speed dial buttons and push the button labeled "data registration".  Using the arrow buttons find the speed dial info and figure it out from there.  Good luck!
Jan 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
Canon LaserCLASS Fax 710 Printer Logo
166 people viewed this question
old marine
old marine
