Question about Brother MFC 8500 All-In-One Laser Printer
Black line down right margin
Fax or copy function gives 1 1/2 inch solid black line down the right margin of the page. scanner glass is clean and no white out or paper stuck over the glass. ?could this be scanner lamp failure? ?can this be fixed?
  • 417 Answers
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Posted on Feb 04, 2008
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black line down page when faxed or copying
Open up the document feeder and clean the scanner glass
Mar 27, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
Line down center of page.
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Dec 04, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
LINES DOWN THE PAGE WHEN I USE AUTO FEEDER
sounds like you need to do a head cleaning. go to control panel on computer and click on faxes and copiers. right click on the printer you are have problems with and there will be a head clean and nozzle check choice run through those.
Oct 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
Brother MFC 8500 All-In-One Laser Printer Logo
412 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
