Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050P won't fill water or spin
I set the spin cycle speed and I choose the cycle type, then push the start button but the machine never fills with water. The Status lights seem to be moving along like the machine is working properly, but it isn't doing anything. After about 20-25 minutes I check the status lights, and the it almost seems like all the lights are glowing, but the "DONE" light is glowing the brightest, so it seems like it's going through the wash cycle, but it never fills with water, and it never spins either; it doesn't make any noise either.
Can someone please assist me.
  • 3 more comments
  • bouchigo Jan 31, 2008
    Well, I found a troubleshooting manual for this washer, but I can't remember at what website. Anyway, I followed the instructions which told me to push and hold the "Prewash" button in and then push the start button. All the LED's turned on as they should. It then is supposed to go through a pre-check test and if everything tests out fine, the "Prewash" LED should turn of, and the other LED's remain lit. When I did the test, the "Prewash" LED never turned off. According to the manual, either the Door Lock Switch, Pressure Switch or the Thermistor have gone bad. I tested them as the manual instructed, but they all tested good. The manual also states that if everything tests out fine, then replace the control module. So, it seems like the control module is the one that needs to be replaced because there is no voltage going out to the door lock switch, so the switch is never engages.
    Does anyone know by any chance how much voltage should be going out to the switch from the control module?
    Oh, this is where I got the manual from, it's pretty big, about 44MB: https://secured.whirlpool.com/Service/Sr...$FILE/WPWASHER1.pdf
    The full website wasn't posted, here it is again:
    website for manual
  • bouchigo Feb 02, 2008
    By control board do you mean the "electronic control module"? I checked the price on them, and they are pretty high ($400). I am almost tempted to just buy a new washer since I read a lot of posts on this particular washer being very problematic.
  • bouchigo Nov 22, 2008
    I got it fixed already. I thought I had come back here and let you guys know, but I forgot. It turns out it was the latching switch that locks the door in place one closed. The switch was not engaging. There was a redesigend switch, instead of replacing the whole door. Once I installed it, it worked fine, and it's been working ever since.
    Thank you all.
  • Anonymous Mar 28, 2014
    Status light and pilot stays on only about 2 hours
  • 3 Answers
I had the same issue with mine, no spinning and occasionally it did not want to start. I did multiple tests on the machine, following all notes/solution from this Web site but it was still not working properly. I was at the point to buy a new "electronic control module".
I decided to remove "electronic control module" and do quick visual inspection before ordering a new one.
I find out that the board was full of little (microscopic) lead (plumb). I cleaned it with a toothbrush and ALCOHOL on both side, re-installed it and since then the machine worked find... Finally after a year I have a working machine.
I think you should test this solution before spending $400 on a new "electronic control module".
Let others know if it work on your side too.
Posted on Nov 17, 2008
RELACE THE CONTROL BOARD
Posted on Feb 02, 2008
    Genius:
  • 1,003 Answers
I SAY REPLACE WATER INLET SOLENOID
Posted on Jan 31, 2008
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Whirlpool washer wet after spin cycle
Hello.
1 Measure your drainpipe to make sure it is no taller than 96 inches in height and no shorter than 30 inches; otherwise, it won't pump enough water from the washer, or the water may flow back to the washer.
2 Look at the dial selection to make sure you have selected the proper spin speed for the material you are washing. Choose the highest spin speed for that particular material. If you choose the "no spin" or "low spin" option, your whirlpool washer might not remove all of the water from your clothes.
3 Check if you have chosen the appropriate wash cycle for the type of material you are washing. The whirlpool washing machine drains quite a bit more slowly on the "Delicate" and "Hand Wash" cycles.
4 Check for excessive soap suds accumulating in the washing machine. whirlpool recommends you use only high-efficiency detergent in whirlpool washers. Other detergents can cause excessive soap suds, which could cause the washing machine to operate at a slower spin speed than selected, resulting in sopping wet clothes.
5 Add more clothing items to the washing load. If you wash only one large item, like a coat or blanket, the washer might become unbalanced and react by lowering the spin speed, causing the machine to not drain as it should during the spin cycle.
6 Examine your drain hose for clogs or kinks. Straighten the hose out to allow water to flow through. Eliminate blockage in the drainpipe or utility sink.
Thanks.
Nov 01, 2011 | Washing Machines
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050P doesnt spin now after repairing drain leak
You should recheck the wireing as you described in your problem and make sure that the water didn't short anything out. If not you should check the motor, motor coupler, the timer, or the start motor capacitor.
Heres a link to help to find the correct parts.
http://www.partstore.com/ModelSearch.aspx?MfgName=Whirlpool&BrandName=Whirlpool&ModelNumber=LHW0050P
Hope this info help to anyone who reads it.
Feb 25, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
410 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
