Question about Kidde Nighthawk Combo Gas/co Detector
TURNING ALARM OFF
LOST MANUAL. CAN'T GET IT TO STOP BEEPING! DON'T WANT TO USE IT AT THIS TIME! CAN'T SEE IF BATTERIES NEED REMOVED....DRIVING ME NUTS!!! HELP!
  • Anonymous May 13, 2008
  • 667 Answers
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 13, 2008
    Model # was not specified. If link is wrong manual correct manual can be found at that same site.
Fire alarm beeping after battery change
you need a good quality fresh battery, cheap or old batteries are not strong enough
Jun 27, 2014 | First Alert Brk / First Alert Smoke...
Stop alarm beeping
If you had a model number (on a sticker inside the fridge), there's probably a manual online that tells how to adjust the door.
Dec 28, 2013 | Kenmore Refrigerators
Umbro watch instructions
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu:Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Jul 15, 2013 | Watches
My bioaxxis bd1 finger print deadbolt lock had to have the batteries changed. I removed the batteries and left the batteries out for a day. Once I installed the batteries, the lock would not work. I get an...
Here is the link to the website for the manufacturer, Axxis Biometrics:
http://www.axxisbiometrics.com/products/locks/deadbolt-fingerprint/bioaxxis-bd1/
I want you to have that because if all else fails, you'll have the contact information for further assistance.
Here is the direct link to the installation and programming instructions, which includes the beep codes. You likely lost the programming when you left the batteries out for such a long period:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Hope this helps. Good luck!
Aug 08, 2011 | Deadbolt Bioaxxis Bd1 Biometric...
Beeping alarm goes off when I reach 135 BPM. Is there a way to reset or even turn off? Omron HJ-113.Cannot find anything in the instruction manual.
Try turning the unit OFF, remove the batteries and wait 5 minutes. Reinstall the batteries and the unit should revert back to the original factory settings. If that doesn't solve the problem. contact OMRON at their Customer Support toll free number, that appears in your Owner's Manual.
Hope this helped you.
Jun 08, 2011 | Health & Beauty
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
I have a British Gas carbon Monoxide alarm - recently changed the batteries but it now beeps once every minuit, instructions on the inside of the cover says refer to manual - but I can't find. Any idea...
I am having exactly the same problem. It says that the batteries cannot be changed (ccould just be ploy to get us to buy a new unit). mine is only 4 yrs old, and has never beeped before - the light used to blink once when i entered the kitchen. It is now beeping intermittently once per minute same as a smoke alarm needing a new battery.
Apr 10, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Non stop trouble beeping every 30 on my simon 3 security system
Two separate problems: Sensor failure and phone communication failure. Most likely, you've not been hooked up to a phone for a while but the system didn't know until it tried to transmit to the monitoring center that you removed a cover on a sensor.
I can tell you how to turn off the panel beeps, "beeps" not only includes the trouble beeps that are driving you crazy, but also the beeps letting you know it's counting down, either when you've just armed it or when you come home right before the alarm sounds.
Open the cover and enter your code using the red numbered buttons inside there. It doesn't beep when you press buttons, so press them well. When you've done it right, it will tell you to choose from the Start Menu. Choose "DELETE". Then, from the Main Menu, choose "OPTION #". Then press DONE. You have now turned off beeps. You haven't fixed anything and that sensor still isn't working but it's not beeping to get your attention now. Press SYSTEM STATUS two times to hear it tell you what's going on.
To turn beeps on again, open cover, enter code and choose ADD > OPTION # > DONE.
Nov 16, 2008 | GE Security Simon 3 Wireless Home Security...
Kidde Nighthawk Combo Gas/co Detector Logo
377 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
